Question about Compaq (388110-001) Pentium III, 450 MHz ( 388110-001 ) OEM / Unboxed Processor Upgrade
Black on two sides of monitor
Black on two sides of the monitor where the screen saver should be also the start menu is gone
  • 1,959 Answers
For the Start menu, I assume you're talking about the taskbar that appears on the bottom of the screen. Press the Windows button on the keyboard (usually located between the Ctrl and Alt button on the left hand side).Right-click on the Start button. Click on the Taskbar tab and check the box that says "Lock the taskbar". Your taskbar should return to your desktop.
Wallpaper (desktop image)
In XP:
Right click on a blank space anywhere on the desktop. Click on graphics properties. You should see a window with your Wallpaper previewed in the top window. Click in the Settings. There should be a setting for "Stretch". Select Stretch and your desktop should return to normal.
In Vista: Right click on a blank space on the desktop, click personalize/display settings/advanced settings Click on your graphics card if available or graphics properties. You're looking for Aspect Ratio options From here you will see a setting with 2 options
  1. Maintain aspect ratio
  2. Full screen (no border)
Depending on your graphics card, this process may differ slightly, but the setting you need is Aspect Ratio
I hope this answers your questions. Best of luck.
Greg
Posted on Jun 17, 2009
The screen darkens slightly, then after 5-10 seconds, the monitor goes black. I have to turn in off, then on again, for the screen to re-light, but it consistently goes black until I re-start my computer....
hi this sounds like the monitor is going into sleep mode, what is happening is that if it is not used for a bit, and there is no screen saver, the monitor will shut itself down, to change this, go to control panel, then power options, double click that, in the menu you will see at the bottom, turn off monitor, turn off hard disks, what you need to do is click the arrow to the left on that menu and choose never at the bottom of the list, you can also do this for the hard drive if you need to do so, then just save changes, and hopefully that should be cured...hope that helps
Sep 25, 2010 | AOC LM729 17" LCD Monitor
My dell computer screen goes black after a while after windows xp second up grade went on. what should i do without taking upgradee off or changing screens?
Right click on your desktop go down list to properties and left click under the screensaver tab click the power tab and turn off the power saver in other words change settings to always on and no hibernation
Nov 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
When PC is not used, screen goes black, then Check Signal Cable
right click on your desktop.go to properties.in properties go to the screen saver tab.click on the screen saver tab.under the screen saver tab you will a tab called power.click on power.change you monitor settings there.let me know if it works
Sep 07, 2009 | Computers & Internet
Monitor has black around two sides
click f12 and that is moniter setting you will figure it out from there
Jun 14, 2009 | Compaq (388110-001) Pentium III, 450 MHz...
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
Nov 13, 2017 | HP W2007 LCD Monitor
Computer
Security Policy is hinding screen saver tab.
Go to Start Menu
Click on "Run"
type: gpedit.msc
click OK
User configuration
- Administrative Templates
- Control Panel
- Display
Look at Hide Screen Saver tab
make sure it is set to disable.
Jun 26, 2008 | Dell Dimension 4500 PC Desktop
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Black screen
check the brighness and contrast of the monitor from the menu button ... try giving reset ....
if same problem persists then the monitor CRT tube may be gone
jsut go expert technician and tell the problem...
if so the technician will recharge the tubes...
Nov 17, 2007 | Sony SDM-HS73P 17" LCD Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Compaq (388110-001) Pentium III, 450 MHz ( 388110-001 ) OEM / Unboxed Processor Upgrade Logo
155 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
