I wanna know where can I buy Electrolux W4180H Inverter? The Wascomat Inverter Part # 472 992922 INVERTER,SU655CC, works in Electrolux W4180H?
brainyass
  • 242 Answers
SOURCE: power inverter
Most likely a fuse. Check for a fuse on the inverter itself or one inline with the plug. Usually you can screw off the tip of the plug and replace the fuse inside.
Posted on Oct 24, 2008
Benimur
  • 6966 Answers
SOURCE: Monitor's backlight inverter shuts down.
Initially, visually inspect for any leaked or bulging capacitors. The problem may be heat related. In the absence of a schematic diagram, you may have to wing it. To verify if it is heat related is to have a can of compressed air or "instant freeze". Soon as the unit shuts down, spray suspected area. If unit resumes operation, you have pinpointed the area to start component check. If it is a major problem, the unit will not even start up. But since it works except shuts down, then again as initially posted heat related.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
  • 19 Answers
SOURCE: Where to buy backlight inverter for DELL 2005FPW monitor
http://www.lcdrepair.us/
Posted on Jan 20, 2009
LaptopNomad
  • 12 Answers
SOURCE: Dell Inspiron 6000 Laptop Screen has Faint Image
Sounds like your inverter has loose components on the pcb. Replacing inverters is not that costly and a relatively easy repair. Read about CCFL tube failure here.
Posted on Sep 21, 2009
Testimonial: "excellent advice and right on, as I have solved my problem by replacing the inverter"
SOURCE: ( Electrolux W4180H ): screen
ELECTROLUX W4180H , THE PROGRAME IS RUNNING OK BUT GIVE AFTER 2 MINIUTES MOTOR TO HOT
THE MOTOR IS OK
WHAT IS THE PROBLEM?
Posted on Sep 23, 2010
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Feb 28, 2016 | Electrolux Washing Machines
How to change a LCD?
Error code 2000-0322 is a LCD INVERTER error but you wanna buy both just in case. I hope this is helpful.
how to replace inverter
how to replace screen
Aug 10, 2014 | Dell XPS M1330 Laptop
Looking for W4180H frequency inverter/motor control
guarantee vacuum and sewing center or order directly off of the website
Mar 19, 2014 | Vacuums
Got a exsm680cl washer and it reads error drain not draining
Check the leveling of the machine, if not use a spirit level and use rubber sheets to keep it firm. If the drain hose is detached the water must freely flow out in this case. If not adjust the slope.
Also check the drain pump to open and work with good action. If not you need to remove and clean the filter and reset the pump
Jan 21, 2013 | Wascomat Parts Wascomat 432 251902 Washer...
Asus laptop and red shadows on letters and bad picture. is this a lcd inverter problem? External monitor works ok.I check lcd panel cable and replace lcd panel but all same
Yep, it's the inverter. Anytime there is a red or pinkish tint or hue you know it is the inverter. Usually the inverter is very easy to change. I would buy one on eBay for your best price...
Good luck!! EJ Kudelka
Oct 18, 2010 | Computers & Internet
It's a faulty backlight (screen).
Replace screen (same dell part number) with inverter, otherwise screen can be dark.
Here is how Dell part number looks (green):
Aug 19, 2009 | Dell Inspiron 6000 Notebook
( Electrolux W4180H ): screen is turned off althought there is voltage in its receptical
THE MOTOR IS OK
Jul 25, 2008 | Electrolux Washing Machines
Ccfl inverter board
The most prevalent failure on these boards are the transformers and or the ic that controls the frequency of the lamp drive. More times than not you will find a bad transformer.
srich
May 19, 2008 | Gateway FPD2275W LCD Monitor
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
