Question about LaCie Cookey Flash USB Key - 32GB
Why my computer is not reading lacie cookey usb
My computer does not load my usb key so I am unable to see the contents on the drive
    Champion:
  • 205 Answers
Your usb key may have failed or it is in a different format that your pc cant read
Posted on Mar 24, 2014
LaCie, hard drive stopped working. Blue light is on, but nothing loads on my computer, no error messages. Unfortunately I haven't backed up the data anywhere and it has a lot of data on it. Can...
Hello there,
First of all, i will say you should try another USB cable in connecting the hard drive to your computer. Or you try to connect it to another computer. This time, ensure you try to use a 7.0 USB cable.
Sometimes the cable might be bad and will just connect but not read you hard drive. It happened to a modem of mine. Until i changed the USB cable was when the computer was able to read the modem.
Hope the hard drive did not fall or hit any hard object.
Hope this helped. Goodluck Elect_Comp
Aug 26, 2011 | LaCie Computers & Internet
I didn't find a port in ma laptop in which i can plug n play b'coz it didn't plug in into usb ports
These are the minimum system requirements of the flash drive you bought.
• Computer with a USB port • Latest version of Windows XP, Windows Vista® , Windows 7 • Mac® OS X 10.4, 10.5, 10.6 • Minimum free disk space: 600MB recommended
Any way back to the question, there is a protective plastic clip for the gold contacts have you tried removing it before using, it might be the reason you cant stick it to any USB port. Any way don't lost the cap so it can lessen dirt on the gold contacts.
Hopefully this information helps.
Thank you for using FixYa.
Aug 15, 2011 | LaCie CooKey USB flash drive - 16 GB USB...
I have a 8 Gb Lacie Moskeyto flash drive, without ejecting it from my laptop, my laptop was left to sleep. Upon starting up my laptop, my 8 Gb Lacie flash drive, was left "Unrecognized" by...
When you switch on your computer press the F12 key that should take you to the boot screen , scroll down to the usb drive and press enter it should boot up to that .
Nov 02, 2017 | LaCie MosKeyto - USB Flash Drive - 16GB...
Lacie 16gb whizkey unable to format in mac
If you have a windows computer, attempt to format it in the drive options (Control panel > System And Security > Administrative Tools > Computer Management > Disk Management, then right-click the drive, format into FAT 32) Otherwise, use disk utility (Applications > Utilities > Disk Utilities) to format it on mac (I don't have a mac right in front of me, but from what I'm reading, it seems to be a straightforward process)
May 02, 2011 | LaCie WhizKey USB flash drive - 16 GB...
I have a lacie 1TB exteranl hard drive and i cant get it 2 read on my dvd player via usb port...any ideas
Dows your DVD player supports reading drives of 1 TB capacity?
Check if the drive works on a computer!
Aug 24, 2009 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
Lacie Hard-drive
Hello my friend, regarding on your problem the contents of your hard-drive is safe no need to worry cause the data is still there. Unless the hard-drive itself is corrupted that's the time your data will lost. To make it safe, you can retrieve the content of your hard-drive either if you have tools and skills in fixing hard-disk then youn open it and manually attach  the hard-drive to your computer using the appropriate conector you have or you can find a technician in your place to fix and scan your hard-drive and to help you evaluate the main reason of your problem and also to save the contents of your hard-drive. Hope this information helps you if you need more assistance then just post some reply in here.
Jun 17, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External Hard drive clicking sound and unable to view contents of
First check the LaCie power supply. I have a D2 HARD DISK EXTREME 250GB model 300770 that had this exact problem. I swapped out the power supply for the higher wattage unit from LaCie and presto, the drive functioned properly. Not saying this will fix your problem but I have personally had this exact problem. If not take the drive and mount it in a PC IDE/EIDE disk slot and see if you can mount the drive and recover your data (points to LaCie controller problem). Note opening the drive invalidates your LaCie warranty. Also note the warranty on my drive was one years and had long since passed. If that does not work, your last alternative it to use a disk data recovery service but that is big $$$$s. Bon Chance!
Feb 20, 2009 | LaCie (300770) 250 GB Hard Drive
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Mar 24, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie Cookey Flash USB Key - 32GB Logo
60 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
