Question about Canon MP-11DX Calculator
Will Not Print Correctly
I successfully replaced the ribbon but the nothing will print completely. I can see partial numbers. How do I fix this?
3 Suggested Answers
dagr81
  • 59 Answers
SOURCE: Select print and paper is blank - all cartridges have ink
dear friend
the thing that you have changes is ink tank, not the whole unit
this problem is with all the machines which have separate ink tank and head assembly
generally head gets blocked and users keep on changing the ink tanks
friend you have to change head also to get your machine working
thanks
Posted on Apr 10, 2009
SOURCE: I have a canon i860
Bought a new printer. It was cheaper than the fix for my canon printer.
Posted on Dec 07, 2009
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
My zebra id card printer p120i does not print very sharp
zebra p120i TROUBLESHOOTING LINK
Printing shows blurry printed image.
Possible Cause:
•Ribbon cartridge may not be correctly positioned.
Solution:
•Check that the ribbon is properly rolled onto the ribbon cores of the cartridge, with no wrinkles.
•Replace ribbon cartridge, making sure it locks in place, and print again.
Possible Cause:
•Ribbon may not be synchronized on the correct color panel position.
Solution:
•Open lid, then close lid to synchronize ribbon.
Possible Cause:
•Cards may not meet specifications.
Solution:
•Use a different supply of cards.
Possible Cause:
•Dust or embedded contamination inside the printer and/or dirty Cleaning Roller.
Solution:
•Clean the Print Head.
•Replace Cleaning Roller
Jan 30, 2011 | Zebra P120i Thermal Card Printer
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Zebra P330i Printer not counting the YMCKO ribbon correctly
!RIBLEN - - - - Get number of remaining panels on ribbon
Send the command !CSA_0
Send the command !CSA_1
Jul 16, 2009 | Zebra P330i Thermal Card Printer
Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Nov 18, 2008 | Monroe 7130 Calculator
Printhead light comes on
if you are using software that using printer please the s600 printer driver to direct thermal mode to solve the problem.
Aug 18, 2008 | Zebra Stripe S600 Thermal Label Printer
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Canon MP-11DX Calculator Logo
37 people viewed this question
old marine
old marine
