Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
Change pin code
How I can change pin code
I need a pin code for a Toshiba tv. Please
hi Cheryl.
Press the "MENU" button, select Prefer, highlight Parental Control and press the right arrow key or menu button to enter the PIN code entry screen. 0000 is the default password. When the correct PIN # is entered the Parental Control Menu opens and you can change your settings and PIN code here.
Changing the TV password
or read up some more at this manual.
Toshiba 19L4200U User Manual Forgotten Pin Code Changing Or Deleting Your...
or this one.
4 digit pin code for toshiba tv Google Search
Dec 17, 2017 | Toshiba Televison & Video
How do i change my pin code
Do you want to change security pin code in your phone ? If so, first reset your phone using Master reset code when you forgot security code . You can get it from the provider Unlock-Free.com as free of cost . After that, change your security pin code .
Nov 10, 2014 | Locks & Locksmithing
These are my numbers 0796086761 and i need mt PUK please
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
Subject: How to unlock a SIM card
Customer's exact description: these are my numbers 0796086761 and i need mt PUK please
Discussion: Problems of this type can be easily solved. Customer did not provide the name of the service provider.
Solution: Provide instructions for unlocking a SIM card
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
Take the phone into your carrier's retail outlet.
OR
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
Second Solution:
You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link: Universal Software Solution for Unlocking a SIM Card
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below I've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing one's PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes.
The Final Solution:
The following methodology does not work for every phone. Perhaps you'll be lucky. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
*# 06 #
Ben
Sep 11, 2011 | Cell Phones
I have written my PUK code then it says enter new pin code so i enter a code and it says code error! please help me!!!!
After entering PUK code, the settings change to default pin code. so please try your phone default pin code instead of your changed pin code. Thank you
Apr 29, 2011 | Cell Phones
SAMSUNG S5233 WHY THEMES IS NOT DOWNLAOD ?
Tired of memorizing new PIN codes? We show you how to change your SIM card's various PIN and PUK codes in less than 5 seconds.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
*# 06 #
<a href="http://www.5starandroid.com">Android Mobile</a>
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
My samsung B7722, first time insert sim card, after enter pin number, error massage came out "phone freeze, sim unavailable, please contact your service provider" how to settle?
Although most people remember their primary SIM PIN code, those othercodes - used for various verification purposes - are never to be foundwhen needed. Below we've included a set of short codes which, whenentered on a handset's standby screen, will let you easily change PINand PUK (short for Pin Unlock Code) codes - but keep in mind, they maynot work with all handsets and mobile operators.
More importantly, when changing ones PUK codesthere'll be no help to get from the mobile operator if the new codesare forgotten, so make sure to write any changes down alongside the oldPUK codes. Also, please note that the codes should be entered withoutthe spaces shown below.
Change SIM Card PIN
*# 06 #
Oct 03, 2010 | Samsung SYNC SGH-A707 Cellular Phone
I am trying to change my PIN2 and PUK codes and to unlock the SIM APP...how do i do this on my own?
Change SIM Card PIN
*# 06 #
Sep 22, 2009 | Cell Phones
I have an lg vu and i wanted to see what happens after the pin is gone 5 times now my screen just sayz puk blocked please need help!!!!!
If all else fails, you can use cellunlockstore.com for $1.99. Try the instructions below.
To change your SIM card's various PIN and PUK codes:
Change SIM Card PIN
Jul 19, 2009 | Cell Phones
Change pin code
To change the PIN number on your mobile phone, please follow the instructions below:
Select 'Menu'
Select 'Tools'
Select 'Settings'
Select 'Security'
Select 'Phone & SIM'
Scroll to 'PIN Code'
Select 'Options'
Select 'Change'
Select 'Enter Old PIN'
Select 'OK'
Select 'Enter New PIN'
Select 'OK'
Re-enter 'New PIN'
Select 'OK'
display_flip('id1308', 'divId1308');
Jun 16, 2008 | Nokia 6600
Sim pin
Change SIM Card PIN
*# 06 #
Dec 01, 2007 | Motorola Mobility RAZR V3
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
Top Parrot Cell Phones Experts
Andrew Wright
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
