Question about Dishwashers
Whirlpool dishwasher leaving debris on top rack dishes
I've had the machine for about 4-5 years and recently it began leaving debris on the top rack glasses/dishes. Usually mostly on the exterior, but sometimes on the inside of the glasses as well. Technician advised me to increase hot water temperature, change detergent, and add more rinse aid. None of those things have helped. Any thoughts? He disassembled the pump, inspected the spray arms, etc. and didn't find anything unusual.
  • Dishwashers Master
  • 16,195 Answers
You did not list the model of the machine. But it appears to me that the disposal in the unit might be in need of work. There are teeth in the machine that grind food.
Posted on Mar 24, 2014
  • 31 Answers
SOURCE: Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Posted on Mar 14, 2009
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 423 Answers
SOURCE: LG dishwasher wont clean top rack dishes
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Posted on Mar 29, 2009
  • 744 Answers
SOURCE: dishwasher not cleaning dishes on top rack
Check the riser tube coming from the pump assembly and be sure it isn't blocked or that something else isn't obstructing the pump intake area. Make sure the upper wah arm assembly isn't excessively loose on the spindle and losing pressure because it's leaking. You may have to remove the lower rack, lower wash arm and cover to see.
If everything is clear, it could be a worn or damaged pump impeller. If the machine drains normally, it's not the motor.
Posted on May 16, 2009
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Top shelf dishes aren't getting clean in my 5 year old Whirlpool dishwasher. Any suggestions?
The most likely reason the dishes in the uppper rack of your dishawasher are not getting clean is because the filter on the pump is built up withe debris and the water is havinga tough time circulating through the pump. This tip i wrote will show ya how to clean that filter.
http://www.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 18, 2011 | Whirlpool Dishwashers
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
The top rack is not longer getting clean
Using liquid detergent is the worst detergent to use. One possible solution to your problem could be as follows...pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. May need to do this several times (3 to 4). This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel, no liquid and no tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Jan 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
If the unit is cleaning the bottom dishes normally, try unplugging the unit for 5 minutes to reset the control board.  If that doesn't work, then the control board needs to be replaced.  The problem is that control board is not diverting the water to the upper wash arm during the cycle.  Possibly a program problem
May 30, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
115 people viewed this question
Top Dishwashers Experts
