Fusing Unit Setting Error
The machine stopped printing while being used remotely. It appears to have completed a job then quit and it says "Fusing Unit Error, Fusing unit is not set correctly open the part as shown ans reset the unit" I can't find the unit or see aything removeable in the side panel that it is pointing me to.
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
It is what it is. No, you can't refill it
Posted on Apr 07, 2009
  • 393 Answers
SOURCE: purchased new fusing unit for ricoh cl3500n;
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Posted on Jul 08, 2009
coupondeal
  • 76 Answers
SOURCE: Problem replacing fusing unit for a Ricoh Aficio SP C411DN
Look in your owners manual for the set of reset keys you ppuch to reset the error in the machine. Can't tell you much other than it is a sequence like holding POWER button and 1 or 2 other keys for so many seconds. Have you tried to ask the question at their website?
http://www.ricohpr.com/
Here is the location for the manual
http://www.ricohpr.com/about/awards/pdf/2006/Ricoh%20Aficio%20SP%20C411DN%20LTR%20%5B34246%5D%20Reprint.pdf
Posted on Jul 15, 2009
  • 3 Answers
SOURCE: reset fusing unit correctly
You need a new printer head. This has happened to me several times with my printer and I know how frustrating it is.
Posted on Mar 14, 2010
  • 15 Answers
SOURCE: Replace fusing unit error
Can you put the old fuser back, just to see if the message clears.
Posted on Apr 16, 2010
Kyocera C6050 error
C6050 Error
Abnormally low fusing unit thermistor temperature
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset
Jul 03, 2014 | Kyocera Office Equipment & Supplies
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
ERROR CODE SC542 ON A RICOH SPC 242
Print Ready Temperature Error
?? The heating roller temperature increase during a set time is not correct.
?? The fusing temperature does not reach the print ready temperature within a
set time after the fusing lamp has turned on.
?? Defective thermistor
?? Incorrect power supply input at the main power socket
?? Defective fusing lamp
1. Check the voltage of the wall outlet.
2. Replace the fusing unit
3. Replace the fusing lamp.
**Execute "Engine Maintenance Menu" to recover the machine after
completing the recovery procedure. Otherwise, the machine continues to
issue this SC code and cannot be operated.
Jan 08, 2014 | Ricoh Aficio SP C232DN Laser Printer
Konica minolta is not switching on
Open a front door and remove a fusing unit and turn ON the copier.If the copier turn on and appear on error code to refer a fusing unit a problem in the fusing unit.
Dec 16, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
Sc546 error. After printing about 10-15 pages machine stops and reads error.
SC 546 - Fusing ready temperature malfunction,unstable fusing temperature.Chek the fuser unit upper fuser roller thermistors,if dirty clean it,check the fusing unit connection or change the thermistors.
Mar 06, 2013 | Gestetner DSc460 Copier
Fusing unit setting error
To prevent damage to the machine, the main machine cannot be operated until the fusing related
SC has been reset by a service representative.
? Enter "SP Mode 3" in the SOM.
Click "OK" in "Reset Fusing Unit SC" with "SP Mode 3", and then turn the main power switch off
and on.
Dec 11, 2011 | Ricoh Aficio 2228C Copier
C6400
C6400 is a fixing unit error. You may need a new fixing unit but most of the time it can be reset in maintenance mode.
Use the following steps to enter the maintence mode, once there follow the steps for maintence mode 163 (reset fuser error). Do not do anything else in the maintenance mode area because you could damage your machine.
Enter the maintenance item number (163) using the up/down keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.)
Completion
Turning power switch off and back on
Description
Purpose
Method
Completion
Turning power switch off and back on.
I hope this is helpful,
Shawn
Feb 15, 2011 | Kyocera Copystar CS-1820 Black and White...
Display the Call service C6400 code
Completion
Description
Purpose
Method
Completion
Shawn
Dec 22, 2010 | Kyocera Copystar CS-1820 Black and White...
Printer won't print. Engine Fuser Error appears on the display.
There is a problem with the fusing unit in the machine. Most common failure is the heating element or thermal fuse. The fusing unit is the part that heats up and "fuses" the toner onto the paper. It is located right where the paper exits the machine. Pretty simple repair. You can buy the fusing unit new from www.precisionroller.com for $119
Their part number is H5244
Good Luck and Thank You for using Fixya
Mar 29, 2010 | Samsung ML-2550 Laser Printer
18 people viewed this question
k24674
