Ricoh aficio mp c3500 fusing unit
My machine was working fine. I came in thi smorning and it has an error that says fusing unit is not set correctly. This happened on Sunday while I was using it remotely, it appears to have been printing fine and then stopped in the middle of a job.
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
  • 32 Answers
SOURCE: Ricoh Aficio MP 2510 netwrok printer all jobs from users are Acce
the reason why the job(s) at the workstation say they are completed, and there is no job at the printer, is because the user code management has been turned ON.
if you turn user code management on, and do not setup users, with user codes, then jobs will continue to run like they are now. either turn OFF user code management, or setup users in the address book of the printer.
Posted on Apr 02, 2009
Ickoajnc
  • 203 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
  • 903 Answers
SOURCE: how to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Posted on May 29, 2010
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Jai un C3500 mp Aficio de Ricoh qui a sc erreur 792
finisher cable not plug into copier. I f you don't have a finisher don't worry about it or you need to remove bridge unit to get rid of code.
Sep 20, 2014 | Ricoh Aficio Mpc 3500 Color Copier
What is sc 532 on aficio mp c2500 and what if the machine shows your that your fuser settings error
"Fusing duplex motor locked" check the fusing duplex gear box or clean if not so you can change duplex motor.
Sep 01, 2014 | Ricoh Aficio Mp C2500 Color Laser -...
Error Code SC 401
1. Check the transfer unit is set correctly.
2. Check the transfer roller is set correctly.
3. Check the high voltage supply board is set correctly.
4. Check the harness of the high voltage supply board.
5. Call a Ricoh Service tech.
Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
I want to relocate my Ricoh Aficio MP 3300
disconnect the finisher reset it and then it will be a monster roll
Jan 05, 2014 | Ricoh SR 790 - Finisher - 1000 sheets -...
Adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Apr 10, 2009 | Ricoh Aficio 2015 Copier
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
21 people viewed this question
k24674
jasbo
jasbo
