Question about Philips Electronics 46PFL3908 46" 1080p LED-LCD TV - 16:9 - HDTV 1080p ATSC - 178AAAA€AAAAA / 178AAAA€AAAAA - 1920 x 1080 - Dolby Digital, Surround Sound - 3 x HDMI - USB - Ethernet - Wi-Fi - DLNA Certified - PC Streaming - Internet Access - Media Player
Philips Electronics 46PFL3908 46 sound distortion
Intermittently the sounds starts to distort after a minute or two it clears up. This started after I plugged in an RCA plug to check out some external speakers. They did not work but the distortion started after this.
    Champion:
  • 205 Answers
Sounds like you burnt up the amp chip only way to fix is to replace thw whole circuit board
Posted on Mar 24, 2014
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
I have a single 15" sub woofer in a box it was
Simply put, burned voice coil. Either too much power can do this or not enough power with distortion. solution- if the sound is clear then its too much power- turn the amp down. If the sound is distorted and raspy- its not enough power and your getting distortion-get bigger amp.
Jan 07, 2013 | Car Audio & Video
At start up, distorted / dble vision fuzzy. Screen will go black with sound. Turn off & on to get very poor distorted picture. After 15 - 20 minutes clears up.
The reason your television is having distorted vision and screen going black with sound is because there is a problem inside the unit. This problem could be caused by either a bad lamp or a faulty t-com board.
My best bet is the lamp, because it is when the lamp start developing any fault it begins the distorted screen thing and coming up black.
What you hsve to do is to get a replacement lamp, open up the television and replace the lamp with a new one, after doing that your television will be in good condition once again.
Take care and good luck
Oct 27, 2010 | Sony BRAVIA KDL-46V3000 Television
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have logitech x220 speaker set up, but I am getting intermittent distortion. Which renders them useless for playing music, they even distort computer warning noises! I have changed from an integral sound...
actually the harddrive could also be the problem, because when you do have a problem with your HDD your computer tend to intermittently hangup or freezes that causes the distort effect on the sound system. Also you could try using your speaker on a different computer or plug it on an mp3 player so that you could eliminate the factor that your speaker has the problem and if not try using another HDD for your computer or worst case scenarion would be changing the motherboard of your computer.
Jun 01, 2010 | Computers & Internet
Recorded acoustic guitar is fuzzy and distorted
Try anouther Microphone sounds like the frequence sprecturm is to low.
Jul 09, 2009 | Samson C01U USB Condenser Microphone...
Have dropped my laptop and the sound is intermittently slow and heavily distorted
You'll need to replace the motherboard, the computer does not have a separate sound card. Very expensive to fix unless you can do the work yourself.
May 31, 2009 | Packard Bell (030069) Sound Card
I have distortion of playing tapes.
Degraded tape, dirty heads (clean with acetone and Q tip but don't get on plastic), dry coupling capacitors.This assumes that the distortion that you refer to is dirty or fuzzy sounding audio.
If a new tape, recorded and played back, sounds ok then your electronics are in good shape. That means your tapes are junk. If cleaning heads takes care of it, well that's pretty obvious. If your capacitors are dried out you will need to bring it in to a repair shop.
Apr 20, 2009 | Audio Players & Recorders
Philips Electronics 46PFL3908 46" 1080p LED-LCD TV - 16:9 - HDTV 1080p ATSC - 178AAAA€AAAAA / 178AAAA€AAAAA - 1920 x 1080 - Dolby Digital, Surround Sound - 3 x HDMI - USB - Ethernet - Wi-Fi - DLNA Certified - PC Streaming - Internet Access - Media Player Logo
43 people viewed this question
Top Philips Electronics Televison & Video Experts
Electro Med Services...
Are you a Philips Electronics Televison and Video Expert? Answer questions, earn points and help others
