Question about Toshiba Satellite 1135-S125 Notebook
White Screen Turn on the laptop and the screen is all white if i plug a proyector or a tv with the Svideo cable o can see the imagen of my desktop on the tv or proyector but not on the lcd of my laptop, each time i turn on the lap the screens turns white and no way to change it, si i have to been working lately with a tv pluged to see my stuff,
  • 52 Answers
Hi this sound like the invert cable that goes from the motherboard to the lcd!if you look on ebay you might be able to pick one up pretty cheap!i had this problem ages ago with a ifriend laptop and just changed the invert which basically is a ribbon and it was okay!
Posted on Nov 02, 2007
How do i hook up a laptop to my gemstar big screen thru the usb port?
I have never heard of that. You will have to hook it up through the SVideo or DMI or HDMI or whatever Video extension you have on your laptop. Get the correct cables to connect to the same ports on our TV you should see computer on your TV screen "desktop" You will also have to switch screens either one of the FN keys will switch you over or you can do it from the video source in the control panel. Audio can be done with a y split audio stereo jack to the headphone jack and the the Y will be the RCA White and Red jacks these will go to the Red and White jacks for audio on the TV from the laptop.
Apr 19, 2012 | Computers & Internet
Please describe your how to hook up and compaq nc6220 to a tv. I have tried an adaptor with the three prong yellow/white/red to a video adaptor but no luck.
The easiest way to hook up any laptop to a tv is with either an HDMI cord, or an Svideo cord. It looks like your laptop supports Svideo, but make sure your TV supports it as well. The connection should look similar to this: snowyrat_0.jpg
If your TV does have the port, go to a nearby electronics store, and buy an Svideo cord. An employee there should be able to help you find one for a fairly decent price. If your TV doesn't have an Svideo slot, you should be able to get an Svideo to AV converter cord along with your Svideo cord. You can connect the Svideo to your laptop and the Svideo slot in the converter, then plug the AV cords into your TV. Hope this helps!
Mar 28, 2011 | HP Compaq nc6220 Notebook
While streaming Netflix from my laptop (via S cable) to my RCA TV, the image on the TV is black & white. Whether streaming or not, when I hook up my laptop to the TV, the desktop image on my laptop...
If the cable is damaged then one of the pins can be bent inside or if it unscrews a solder connection may be undone. see the photo showing color on the left and bw on the right. Also plug everything in turn off everything then turn on the computer and then turn on tv. also try just opposite turn on tv and reboot computer.
Go to Bing homepage Video Wikipedia SVIDEO TV BLACK AND WHITE SCREEN Graphics Cards
Nov 12, 2017 | RCA F32649 32" TV
What channel do i go to for svideo cable??
The TV doesn't output the TV as such, UNLESS it has what is called a "Monitor" Output Sockets on it. Then you can connect up to, say another "Screen" or Take the Outgoing Video, & Sound, and "Record" it to a PC, via a Video INPUT via a TV/Video INPUT card. BUT you cannot play the TV on the laptop, FROM the TV. like you wish to do. If your laptop has a TV card INSIDE your laptop, then you could use that and display the OUTPUT from that TV cards' tuner, on the TV. But not the "other" way around. That SVHS is ONLY an INPUT out from your PC. You can put you system into either "Cloned"mode, IE: Whats displayed on laptop screen,is also displayed on the TV, Or, you can have as you seem to now, Extended Desktop. I hope this clears things up for you. Also when using that SVHS connection the Audio comes OUT on the Red & White AV sockets on the set. So you need that cable and another pair for the Audio..
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
Picture is black and white with a dvd movie
If you're using the 3 component cables for video, one is probably defective or not connected well.
Dec 29, 2009 | Bose Lifestyle 38 System
your TV has composit video in but your DVD/VCR only has Component video and Svideo outputs ..those are not compatable with your tv .. if you look more closely you might find an SVideo input on your tv .. its flat and not as easy to see as the normal jacks .. if your tv does have SVideo then all you need is an SVideo cable (plus the two sound cables) ... i could check on what you have if you give the TV model number .. othwise you have to have something to convert your SVideo to composit video .. there is a cable that does that .. you can check with radio shack .. if they do have such a cable then one end would plug into the svideo of the dvd/vcr . the other end would plug into the yellow jack on your tv .. hook up sound and it should work ok ..
here is such a cable on the internet ..
or google "svideo to composite" to see lots of options
Nov 22, 2009 | Sylvania DV220SL8 DVD Player/VCR
I cannot get my computer and Infocus LP10 to communicate. This is a new problem. In the past, I hooked everything up and when I powered up the camera and then powered up my laptop, all was well with my...
if you are trying to hook the laptop to the proyector, did you try right clicking on the desktop to view the properties of the screen?
you have to right click at the desktop, then go to properties, then go to the tab of configuration then click on the second screen that will apear, and when it greys out, you there is an option you have to click below that says "extend windows desktop to this monitor", of course, the proyector has to be already conected, when you already clicked that, touch the sync button of the proyuector and it should be working.. otherwise, at the windows of configuraton you have to click on advanced (wich is a button almost at the bottom of the window) and then a window will emerge and (on my version) there is a tab that its called like my video card of the laptop (in your laptop it should be called like your video card), and there must be an option (after you plugged the proyector) of sending the signal like something specific, like a signal for tv, or proyector,or monitor.. .i think it varies depending on the model of the video card.
well.. i think thats all about it.. wish you good luck in your lecture..
also.. check the cables!.. if they are old they could be broken at the begening of the conection... (did i explain that right?)
Apr 03, 2008 | Computers & Internet
No color
does the tv use Svideo as an input from whatever device you're using on the main screen? if so , try changing out the cable for a new one, svideo carries 2 signals, color and brightness (ie color and black signals) if your cable is bad or broken, you may only be getting one of those signals ( the black one) try a new cable if it's s-video. if it's not, get back to us.
Sep 13, 2007 | Hitachi 50SBX78B 50" Rear Projection...
Toshiba Satellite 1135-S125 Notebook Logo
207 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
