Spin cycle on samsung sw56app does not work
My sw56app samsung washine machine stops working once it gets to the spin cycle and leaves the washing machine full of water, it makes a continuos grinding noise but doesnt spin or drain water
  • 10 Answers
SOURCE: washer make a grinding noise in the spin cycle; barrel does not spin in spin cycle
check the transmission out or it can be a clutch problem
Posted on Dec 14, 2007
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
michiganfan9
  • 179 Answers
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Posted on Dec 29, 2008
  • 97 Answers
SOURCE: Whirlpool washing machine makes grinding noise
Hello Friend, Your solution is a real quick fix. The problem you are having is very common, your motor coupling has broken and that is what's making the grinding sound, also in this condition it will always pump out the water. Go to your local appliance parts store and purchase a new motor coupler, your cost should be under $25. It's very simple to remove old and install new coupler. First remove two screws from control panel and tilt control panel backwords exposing area under panel. You will see a metal clip on each side of cabinet under panel. Remove these clips, and unplug wires from plug in on cabinet. Remove cabinet by lifting up in back and tilting forward. Once removed you will see the innerworkings of your washer. Lay washer on it's back and remove the two spring clips that hold water pump in place and remove water pump. Leave water pump hooked up just move to side out of your way. Then you will remove the two screws that hold the motor clips in place and just snap the motor clips off. Be sure to unplug the wire harness plug from the motor. Just simply lift the motor straight up and off of the transmission. There you will see the motor coupler broken and to replace, just pry old one off transmission and motor with large flat head screwdriver. You will notice that one half of coupler is attached to the motor and the other to transmission. In the coupler kit you will receive both pieces and the rubber center connector. Just replace all the old with all the new and your problem will be solved. Happy to help, Tim.
Posted on Jun 24, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Can you tell me what e6 on the display means as the machine wont work when this shows
Not sure of the make/model, but with Samsung washing machines that usually means 2 things. If you get it when entering the spin mode and the system stops and displays the code, the water heater is heating too quickly. Press the power button once to clear the code and finish the cycle before repair.
If you get the E6 during the spin cycle that can mean a problem with the main controller board.
You can keep resetting to get past that code but if you continue to get it during a spin cycle or part of the laundry where hot water isn't used, then usually that controller board is bad.
Good luck.
Apr 08, 2015 | Washing Machines
Sw56app with DE message
On your Samsung washer, the "dE" error code typically occurs just after the rinse cycle. This will leave your machine filled with water as it does not drain because the washer thinks that the lid is open. Reset the cycle to properly drain the water then stop it before it fills up again.
Check to make sure nothing is preventing the lid switch from letting the cycle continue. Debris, such as lint or paper, could have fallen into the switch hole. Rust or an object could also block the hinges on the back of the lid. Clear anything off of the washer that may interfere with the lid switch then try to run the cycle again.
Dec 04, 2012 | Washing Machines
My Bosch machine is not spinning properly leaving my washing still really wet. Tried cleaning pump once before and it worked but it's not worked this time round. At 1200rpm the cycle is really s
Bosch machine is not spinning properly leaving my washing still really wet This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jun 21, 2012 | Washing Machines
My daughter has a samsung sw56app washing machine and it fills with water and washes but wont pump out to rinse and spin
That means the drain pump is broken and needs to be replaced.
Perhaps you need to check if the drain hose is correctly installed, sometimes a bend is not letting water get out.
Nov 05, 2009 | Samsung Washing Machines
Will agitate but won't spin leaving the water in the tub.
the transmission may have been damaged during the runaway.to much movement can cause it harm that is why they come with a shipping rod in them.
Aug 08, 2009 | Kenmore 22422 Top Load Washer
Beko WMA 10W
MY WASHING MACHINE WILL NOT SPIN BUT IT DOES EVERTHING ELSE
Dec 27, 2008 | Washing Machines
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
Intermitant fault zanussi zwx1506w washine machine
try these two things first:check the brushes on the motor you will have to remove it first they are held on with two screws on each,and also there is a drain filter behind the kick plate at the bottom of the machine if this is blocked it does sometimes cause the machine not to spin properly hope this helps
Mar 06, 2008 | Washing Machines
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
