Question about Sanyo Katana SCP-6600 Cellular Phone
Sanyo kantana cel to make a fkash pfffffhone
I want to do a flash drive on it
Crank, no start on 1994 honda accord EXi
you might need a fuel pump relay under dash 10 min fix/and your d4 flashing light bad transmission.
Mar 05, 2014 | Cars & Trucks
I have tdk flash 8 gb and i left it on the port in my computer when i make new windos to my computre and after that i found my fkash not work
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
Jun 06, 2012 | TDK Electronics - Others
How to reset computer on 2004 gmc envoy
If you are talking about turning off the check engine light (CEL), a simple reset will not work. The reason for the CEL being on needs to be addressed first. There are fault codes generated by the computer that can be read a OBII reader. These codes identify the area or sensor where the problem exists. One thing you never want to do is drive the car for longer periods of time with a flashing CEL. A flashing CEL indicates there is a problem that could possibly harm the engine or catalytic converter.
Jun 30, 2011 | 2004 GMC Envoy
I have a Kantana Eclipse Cellphone. How do I take out the sim card?
I believe Sanyo Katana Eclipse is a CDMA phone. It doesn't have a SIM card so, you can't take out SIM card.
Mar 13, 2011 | Cell Phones
I have a Kantana eclipse. How do I take out the sim card?
I believe Sanyo Katana Eclipse is a CDMA phone. It doesn't have a SIM card.
The screen on my phone is all black spots? Nothing works!!!
Usually the LCD screen is connected via flex ribbon wire. Either this needs replacement or the LCD itself.
Aug 28, 2017 | Sanyo Katana SCP-6600 Cellular Phone
Camera won't flash
Check your batteries and if that is not the problem, you have nothing to lose take off the back and see if the wire or some debris is obvious. If not your camera is just a parts camera then. Let me know how it goes
Aug 13, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
Sanyo Katana SCP-6600 Cellular Phone Logo
14 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
