My screen is to little and i cant see the words
My screen is to little and i cant see the they are so small and tiny
    Problem Solver:
  • 5 Answers
Change the screen resolution what operating system are u using?
Posted on Mar 24, 2014
Automatic transmission wont shift, its now in drive,so i cant shift it into park in order to start car. cant check fluid level blah blah blah. 2000 corolla
your gear is stuck , there is a little magic cover in front its base with tiny hole for a tiny screw driver to uncap it , and then use a small screw driver to push the lock lever down ( do that as you have your car switch ignition key on ON position ) and then you be able to shift gear to Park , then close that magic cover on that tiny hole .
if that does not work ? check if your brake lights are bad, harness melted , brake switch , or brake fuse .
Corolla tend to have that shut down of shifter as a safety feature .
if that is not the problem ?
then you have a shift solenoid kicked the bucket and need new one
Jul 24, 2017 | Toyota Corolla Cars & Trucks
Keeps saying card protected when I inset the SD card
Hi Scott - There is a TINY little "slide switch" on the edge of an SD card that is quite easy to accidentally move. It's purpose is to keep important stuff from being accidentally erased. If you look in the image below, just to the left of the word "Extreme" you'll see the slide lock - it's small, in the "notch" to the left of Extreme. You'll also see that the word "Lock" is written vertically and points down (in this case) to indicate which way is locked. This disk is unlocked. Best wishes.
Jul 09, 2015 | Cameras
How do I get the little adapter out that is stuck in there. can't get it out Help!
you kilt it.
find a helpful nerd .
pull it out can damage it or whats left .
a little sugery is now needed .
or a tiny tiny squirt of wd40 but that can leach around the screen.
anything i tell you to do will likely lead into its disposal unless you get tech help.you have to be fearless to work on some things
we would need a lot more info on this to do this exactly.
Nov 28, 2014 | Video Cameras
Packard Bell how to take out DVD writer
usually there is a small cross headed brass screw underneath laptop case that needs to come out
turn over laptop when off
look for door to cd/dvd player
trace your finger in middle of door about 2 to 4 inches in case on bottom
should see a small screw there
will require a tiny phillips head driver to remove
then should slide out with a little push on base of drive housing
May 24, 2012 | Packard Bell Computers & Internet
My computerr screen is too little how do i ajust
by going into start> control panel > and display you can adjust the resolution of your screen here is a list of the correct sizes for the screens Please let me know the outcome of this, if it says frequency out of range then youwill need to download the drivers for your graphics card before doing this.
14" 15" 17" 19" 21" 640x480 BEST GOOD TOO BIG HUGE TERRIBLE 800x600 GOOD BEST GOOD TOO BIG HUGE 1024x768 TOO SMALL GOOD BEST GOOD STILL GOOD 1280x1024 TINY TOO SMALL GOOD BEST GOOD 1600x1200 TERRIBLE TINY TOO SMALL GOOD BEST
Jul 06, 2011 | Computers & Internet
Yes please help us why it looks like so small
If you are referring to the desktop and the icons being small, just change the screen resolution. Right click your desktop and choose Properties or Screen Resolution. Just decrese the resolution if you want the icons to get bigger. Otherwise, let me know what is seem to be small.
Apr 30, 2011 | Computers & Internet
Words to small cant read
You can fix this problem by changing the screen resolution. Go into Control Panel - Display - Settings and change the screen resolution to something lower. Try setting it to 1024X768.
Jun 10, 2009 | Acer Aspire One A150-1006 Notebook
Blue spots on Sony High Definition 41 inch tv.
There are tiny screens at the top and bottom of the lightbulb (XL2200) that allow air for cooling over the lightbulb. It appears that if air flow is restricted the heat is not able to escape. The light source is in direct proximity to another mirror like device called the integrator lighting system polarization changer element. This may have gotten a little hotter than normal and is changing how the light is passing through to the tiny LCD's which make up the light engine. Creating the small areas of lavender light we are seeing.
I myself have replaced this bulb and now will check every months to vacuum the dirt off the tiny screens.
Apr 26, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Router repair
get one of the tiny little torches you use to thaw locks ( not muck bigger than a propane lighter put a small amount of heat all around the Collete and re-try you'd be surprised
Nov 04, 2008 | Tools & Hardware - Others
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
