Question about Canon MP-11DX Calculator
Changing Twin Spool Ink ribbon
I checked the manual and I thought I had the ribbon replaced properly but when I'm printing it looks wrong.
2 Suggested Answers
  • 2692 Answers
SOURCE: MP610 Black Ink Not Printing Properly
Fix Ya?
Posted on Mar 07, 2009
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
How do I change the ribbon in a Remington sperry rand typewriter?
I was a typewriter tech for seven years. To see if your ribbon needs replace gently pinch it with your finger you should get some ink on them, if not, replace ribbon. Generally speaking, step one if your not sure how to change the ribbon take a picture before you thing , this will give you a chance to get it back together. New ribbon install/ 1. Look at the ribbon, with the hood up,type, and watch to see which spool is paying and which spool is taking up. 2. With your finger turn the take up spool until the ribbon is all on one reel. 3. Note how the ribbon sits in a guide on both right and left spools ( take a picture) 4. The tuff part,the ribbon is laced thought the "hammer block" where the type-heads go to strike the ribbon. (Take a picture) either you lift and lower and lift to " unthread" the ribbon or the other way around, it's not rocket science just note every move you make take pictures. If you get stuck or need further info send back info and pictures and we will go from there. Tip, when typewriters where replaced buy computers many typewriter service company were in the beginning phases of the copier revolution. Many type techs began working on both, you may find help from a long establish local copier company. Good luck, Bret
Dec 26, 2014 | Office Equipment & Supplies
Zebra S600 not printing..replaced ribbon withe as paper/ribbon light solid..still no print after attempting reprint many times (the printing result are white labels)
Just a thought, Zebra Ribbons are Coated Side Out. Take a piece of tape and press it against the ribbon, ink should come off on the tape.
If not then make sure the ribbon is the correct type and that you have it loaded properly. Also, if you use multiple ribbons i.e. wax, wax resin or resin make sure that you have the correct ribbon for the media installed.
Hope that helps.
mikeo@acebarcode.com
www.acebarcode.com
Aug 21, 2011 | Zebra Stripe S400 Label Printer
The ribbon is printing blank labels
Is this the correct ribbon for a Datamax? The ribbon (satndard setup) is for the ribbon to inside wound whereas most printers are outside wound.
You can check this by using the sticky side of a label it will pull off ink (turn black) if it is there.
If this is the wrong ribbon do not be tempted to put it in the other way or you could damage the ribbon supply spool.
Aug 19, 2011 | Datamax DMX-I-4208 Label Printer
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
Ribbon feeds out with label
Your take up spool isn't working properly, bad motor or belt.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
I have a Sony UP-DR150 digital photoprinter that displays "Check Ribbon" I have tried changing both ribbon and paper at the same time but still keep getting same message, any ideas?
Have you tried to Replace the Ribbon and Paper? Make sure the Ribbon must be Compatible and of Appropriate Size. It should not be loose. This message would Appear until Door is Open. Once you Replace the Ribbon and close the door, the message would disappear.
If not, Unplug the Printer for Few Minutes, say 15 minutes and then Turn it ON. That would Reset it.
Note - There was an Upgrade that was done for the software. If you have not Upgraded the software, this message would be there. Upgrade the Software and the message would disappear.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 23, 2010 | Office Equipment & Supplies
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Mar 27, 2009 | Zebra Z4M Printer
Ribbon empty
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
Canon MP-11DX Calculator Logo
21 people viewed this question
old marine
old marine
