Question about Hotpoint Washing Machines
AQM8D69I Door lock wont release
    Problem Solver:
  • 10 Answers
Pull the door release cord at the bottom of machine. make sure there is no water in the drum.
worst case scenario is you may need a new interlock or module(thats if it keeps clicking)
Posted on Mar 24, 2014
2003 VW GOLF REAR door wont open
The rear door lock actuator has failed in the door locking unit this is a common problem you can manually unlock the door to replace the latch if you didn't have the deadlocking on if you cant try pressing the locking button twice so when the car is locked the flashing red light is not blinking ie off on the drivers. Doing this usually causes the faulty lock to release the dead locking so you can pull the inside handle to unlock the door.
Oct 13, 2016 | 2003 Volkswagen Golf
My washing programme has just finished but my door now wont open
I presume you have waited long enough for the door release to operate after a few minutes. POWER OFF! remove lid and lide arm down in side the front panel to the door lock and release the door lock. A new lock is generaly required
Oct 03, 2014 | Washing Machines
Back doors wont lock
Check that the release mechanism is not held up. Adjust latch. Check that the door catches are not on the first step preventing full operation of the door lock
Apr 04, 2013 | 2005 Volkswagen Sharan 1.9
Hello my splendide wd2000s wont drain or spin and wont release the door lock...what do you think
If the machine senses that there is water still in the tub, it will not release the door. Unplug the machine you should her a click and the door should release itself. should take about a minute. As far as the drain and spin, remove the washer/dryer back and check the drain pump, check that the lint filter is clean and that the drain hose is clear of foreign objects. I have instructions for how to unlock the door when the machine is in a cycle. If you're door lock is continuously giving problems,i can walk you thru the steps to test it, to see if needs to be replaced. Lets start with those solutions first, if they don't work we can go to the next step, which would be to test the drain pump and the door lock, and also to put the machine in diagnostic mode
Feb 07, 2011 | Splendide 2000S Front Load Washer / Dryer
My machine has the door lock light on and wont start, the door is locked as i have to press the release to open it!
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD63 Front Load...
Power door locks stuck wont release 1989 toyota camry help....
sounds like the lock might be corroded. or the actuator is faulty might have to pull the door panel while the door is closed & try to get the lock to release.
Good luck
Dec 02, 2009 | 1989 Toyota Camry
Canon elph 2 film door wont open , tried to open with door release button but wont budge.
You need the camera powered up and all the film used to activate the release mechanism for the lock to release the film door, the Elph film door will not open until all the pictures have been taken. It uses A CR2 Lithium battery
Sep 04, 2009 | Canon Photography
406 hdi pass door lock wont lock so car wont lock
Remove the door pannel and spray releasing oil over the central locking solinoid.That should sort it for you good luck.
Sep 02, 2009 | 2005 Peugeot 405
Quad cab rear door closed and wont open
what you have to do is make sure door lock is in unlocked position put a flash light inside the door to see you need to get a screwdriver into the release spring area try to pry up on the hook area that flips over the piece thats mounted to the door jam it should release sounds like you need to spray wd or blaster in the lock assembly return spring not kicking back
Sep 11, 2008 | 1998 Dodge Ram 1500 4WD
Washing Machines Logo
18 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
