Question about GE Profile PD968 30" Drop-In Electric Ranwith 5 Heating Elements, Tri-Ring Element, Bridge
Seal tape WB06T10007 necessary?
Do you need clear seal tape(part WB06T10007) between new replacement top and the bottom part of the drop in unit?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Yes
Posted on Jul 10, 2014
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
I have an elecrolux E36EC70FSS2. The strip of stainless trim between the controls and the burner has come unglued and bows up when the lower elements are on. What adhesive do I need to resecure it. I...
there are Solder cool, they sell in any auto parts, is speciall Glue for seal any things. Solder in Cool. contain 2 parts a+b Buy it and fix it.
God bless you
Sep 24, 2012 | Electrolux 37 in. Designer Series...
I understand all the troubleshooting / repairs for this cooktop (Maytag / Whirlpool CSG7000), but I need to know...How do I separate the glass top from the steel pan without breaking it? Can't get at the...
You will have to use a putty knife to separate the top from the burner box.
After you do your repair you will also need 107 inches of burner box tape to re-seal the top.
Jul 26, 2010 | Maytag 30 in. CSG7000 Gas Cooktop
One of the knobs will not turn at all in either direction. How can I get it to turn?
The picture shows a drop in glass cook top (electric) You have to pull the top, disassemble it from the bottom and replace the switch. Most switches have five wires on them L1 L2 which are your hot 240v, h1 h2 which go to the burner(dual burner switch has h3 h4), and p is the pilot. Terminals are marked, just change one wire as you go or mark the wires as you change the part. Make sure your house breaker is off, no power to unit when working on it . Be careful of the glass top when working on it
Feb 24, 2010 | Jenn-Air JED8430 Electric Cooktop
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 | Cooktops
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
Supporting a ceramic cooktop
Yes. It is. i always feel weary when i see it to however the top is not glass its ceramic so it is a little stronger.if you are in fear wrap tape all the way around the top and tight. if the top is tempered then wrapping the tape around it would make it almost indestructable.
Nov 21, 2008 | Cooktops
Replace burner seals of gas cooktop
good day,
hope this link below will solve your problem.
kitchen
Sep 03, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
GE Profile PD968 30" Drop-In Electric Ranwith 5 Heating Elements, Tri-Ring Element, Bridge Logo
100 people viewed this question
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
