Question about Casio Sea Pathfinder SPF70-2V Wrist Watch
I AM I am SEEKING A PRW5100-1BJF REPLACEMENT BLACK TITANIUM BAND
I want to replace the resin band with the black titanium band I have seen on other watches like the one I own.
    Problem Solver:
  • 8 Answers
Better is to replace at nearby casio service center. otherwise look out here:
http://www.tiktox.com/casio-straps-and-spares/pro-trek-straps.html
or
http://www.watchbands.com/category.aspx,,categoryID,,767
Posted on Mar 31, 2014
  • 1141 Answers
SOURCE: change casio g shock resin watch band
It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
make sure you keep all original parts in case of toruble
Post a photo if you can after the change will be nice to see the change
Tom
Posted on Nov 10, 2008
SOURCE: wrist band adjustment
In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
Posted on Dec 06, 2008
escapement
  • 2334 Answers
SOURCE: 3747 Replacement Watch Band
Use this link to get in touch with Casio:
http://www.casio.com/home/
Choose relevant application under the SUPPORT. Here you can find Technical Support, Casio Parts etc.
Choose your nearest region and ask to supply new watch band.
Do not forget to rate, please.
Posted on Jan 13, 2009
escapement
  • 2334 Answers
SOURCE: How do I get the pins out of the titanium band for Casio PAW1500T
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 09, 2009
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
Hello I need a replacement band for Nautica wach N17524
FOR NAUTICA BANDS GO TO:
GO TO: http://www.ebay.com/sch/bluss_929/m.html?item=221597748969&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
Feb 14, 2015 | Nautica Mens NST Chrono N17526G Black...
Neeed a replacemet strap, band or metal bracelet for Nautica N19558G Black dial Resin Mens watch
You can get it from Authorized Dealer of this Company. If it has nothing to do with it's warranty, any alternative shop will be an economic option.
Mar 29, 2014 | Nautica N19558G Black dial Resin Mens...
BG1301 Casio watch replacement band
Go to "casio.com" and click on "support".
Although they don't say so directly, their repair section imply that they can replace straps.
Jul 20, 2010 | Casio BG1301-4V Pink Baby-G Watch with...
Adjust Watch Band
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Feb 24, 2010 | Timex Ironman Triathlon Hi Ti Watch,...
My gunmetal titanium band (only half of the band is broken, what do I need to get it repaired or replaced???
some watches provides bracelet parts to replace, like rado, tissot etc...otherwise you have to replace whole bracelet, as per my experience titanium cant be solder nor repair
Feb 23, 2010 | Skagen Signature Mesh watch
Discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Jan 25, 2009 | Nautica N07574 Wrist Watch
Casio Sea Pathfinder SPF70-2V Wrist Watch Logo
148 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
