Question about Astar Televison & Video
Astar mp 32hb
I have a astar mp 32hb that iwas using as my desktop monitor. I want to use this as my tv now. The cable in my room has a cable line that u would normally plug into the back of the TV. The astar doesnt have this connector. how do i use the astar with my cable plug? the plug im talking about is like the ANT IN plug where u plug it in then twist to tighten it. I notice most new tv doesnt have this anymore only the old tv does.
    Top Expert:
  • Astar Master
  • 36,394 Answers
Can't be done.
Posted on Mar 24, 2014
  • 15 Answers
SOURCE: SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Posted on Dec 30, 2007
  • 6 Answers
SOURCE: Astar TV shut itself off and never can turn it back on
did you check the power supply capacitors, all the models of astar had this problem. You can tell the bad ones because they are puffed up on top. This fixed my problem and many other peoples. They used cheap parts so cheap results, they are out of business
Posted on Apr 11, 2009
appman67
  • 33 Answers
SOURCE: how to hook up flat screen monitor??
The new flat screens hook up the same as the old CRT monitors.
Posted on May 03, 2009
  • 176 Answers
SOURCE: new flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Posted on Jan 06, 2010
BElectric
  • 1140 Answers
SOURCE: I need to know if I can get a replacement part for
Yes you can get a replacement part, but you will need a new main board. The socket where the cable line attaches is soldered to the main board. It can be re-soldered as long as it's just detached from the main board, or if it's broken a decent TV repair shop could probably get a new socket and solder it on for you. You can see in the image below where all the sockets are attached to the board:
http://cgi.ebay.com/ws/eBayISAPI.dll?VISuperSize&item=370454033509
If it's broken or you can't get someone to repair re-solder it, This is the part you will need:
http://cgi.ebay.com/370454033509
Hope this helps.
Regards,
BElectric
Posted on Nov 20, 2010
Iwas wondering if i could use it as a tv if i hook my cable box to it?
You can, if your cable box has RGB component or s-video or composite outputs and if you can change channels through the cable box.
RGB will give the best picture.
You could also run a vcr into the monitor and use the vcr to change the channels if the cable box will not do the channel changes for you or if the cable box does not have the right outputs.
You will also need a audio output jack on the cable box or vcr to run out to a receiver or stereo or to the monitor speaker bar
Oct 18, 2010 | Gateway FPD2275W LCD Monitor
How can I make this TV work in Europe?
This TV designs for NTSC format, you can not use it outside US. You have to buy a converter to use it with PAL system.
Aug 14, 2009 | Astar MP-32HB 32" Television
Power-AC Adaptor Have input specs but not output
http://www.thepowerclinic.com/services/our-work.html?start=6
is a starting point this model is exceptionally bad with PSU's
astar-ltv-32hbg-2.htm">http://www.shopjimmy.com/power-supply-unit-3bs0142514gp-from-astar-ltv-32hbg-2.htm
You may have problems actually getting one as the company was not in business very long so not many people had gotten repair stocks.
apparently the 3 common parts to fail are the switch, primary & secondary input smoothing caps. and the input chip on the PSU
You may well be able to get it repaired at a decent tv repair shop.
Sorry I could not be of more help
Ifthis post was useful please click
Jun 01, 2009 | Astar MP-32HB 32" Television
I have a 32" Astar LTV ASB TV
Astar LTV-32ASB model problem? I know someone who's know more about astar TV. Just contact him at 323-767-6030 and maybe he will help you go through this problem.
Nov 30, 2008 | Astar LTV-3201 32 in. LCD Television
ASTAR 19" LTV-bs/bg HD/TV
If you still can't reset your TV by holding the enter button please call my friend at 323-767-6030 he may help you go through it.
Sep 23, 2008 | Astar LTV-19BG TV
ASTAR 20'' LCD TV
TO ALL WHOM IT MAY CONCERN REPLACE THE WHOLE SUPPLY WITH NEW ONES AS IN 2OR3 SEPARATE ONES FROM HALTED ELECTRONIC SURPLUS OR HSC IN SUNNYVALE CALIF 408 AREA CODE LOTS OF ROOM
Feb 16, 2008 | Astar LTV-3001 TV
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar LCD HDTV Monitor
mine also does the same thing on a 30' model and have found out it is a burned out power supply....unfortunately i have been unable to find repair parts because the company has been forced out of business...
Nov 08, 2007 | Astar LTV-3201 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
