Question about Corel Print House Magic 3.0 for PC
ConfigDir not found in the registry
Windows 8.1
  • L L Magnusson
    L L Magnusson Mar 25, 2014
    Kompatibilitet s problem
File transfer
remove the usb device
try deleting the registry entry.
reboot
reconnect the device
If it does not work, Try a re-scan at regedit.
If it works, back the registry perhaps using the export function.
How to backup Registry of Windows 8 or 8 1
This helps only if you do not change the OS and add/reconfigure hardware frequently
Aug 28, 2016 | HP Computers & Internet
Get the following error message: Your registry
If you are installing this on Windows 7 or 8 you will have to contact Microsoft directly. You can use Microsoft Technet or knowledge base to try to find a solution but I have found a bunch of this same error on their site and it appears to be a major problem.
I do know that the registry error is often a mistake and the program may run correctly after you reboot. This is a serious issue with Window 7.
Oct 15, 2013 | Microsoft Streets and Trips 2013 B17-00563
Where can I find my windows 8 product key if it wasn't sent in an email?
If you couldn't find Windows 8 product key, try to use iSunshare product key finder to recover Windows product key. All the product keys would be found out, including Windowssystem, SQL Server, Windows 8 or 8.1 product keys.
Sep 10, 2013 | Samsung Computers & Internet
Drivers windows 8
Visit the manufacturer website to download the drivers. Once there enter the model number of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing drivers issue
Jul 03, 2013 | Toshiba Tecra A10 (PTSB0A-00E001/B1) PC...
I m trying to install internet explorer 8 but .it show no entry found.how can i solve the problem
You've tried to install IE version 8 on a windows system (would like to know WinXP/Vista/Win7 ?) that has one or more registry problems. FIX: run a registry sanity checker/fixer appropriate for your version of Windows and retry the IE8 install - the install will
remove (clean out) any invalid/useless IE8 junk already on the system - such as your invalid IE8 registry entries.
www.pctools.com offers a Windows registry checker, but Microsoft offers SCANREG.EXE free - see:
www.support.microsoft.com/kb/183887
for appropriate command-line switches.
Dec 27, 2010 | Computers & Internet
My vista does nnot recognize one partition on my
1. In the run command (Start menu bar) type "regedit" to bring up the Registry Editor.
2. In Registry Editor, navigate to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion
3. In the details pane, double-click DevicePath.
4. Add a semi-colon to end of the existing text, and then add the path to %SystemRoot%\System32. The result should be similar to: %SystemRoot%\inf;%SystemRoot%\System32
Do not remove the %SystemRoot%\inf file path from the DevicePath registry entry.
5. Click OK to save the new value, and then close Registry Editor.
6. Delete “INFCACH.1” FROM C:\Windows and C:\Windows\Inf Directories (if it exists)
7. Ensure that there is a copy of the usbstor.inf file in C:\Windows\Inf
If there isn’t – follow the below steps:
a) From another Vista system (copy it out of another Vista system and copy it directly into the C:\Windows\inf directory
OR
b) From the problem machine, run Command Prompt ( as administrator). From C:\ do a dir usbstor.inf /s . Wherever the file is found, go to that directory and copy all the files located in that directory to C:\Windows\inf directory
8. Open device manager, uninstall all unknown devices (right click, uninstall) so they all disappear from the list
9. Reboot the computer
10. Plug the device in (the drivers will now install and the device will be usable!)
Mar 06, 2010 | Electronics - Others
Want to install Adobe 9 but keep getting Error 1606
Error "1606: could not access network location \Startup" occurs when installing Adobe Creative Suite 4 products or Acrobat (8 or 9)Check out this website for the fix to this issue.
http://kb2.adobe.com/cps/402/kb402867.html
Jul 30, 2009 | Computers & Internet
Can't get rid of bloodhound pdf 8 and now I can't get into my user profile
You are going to have to get your hard drive wiped and windows re-installed then you will be able to have your computer up and running again!
May 07, 2009 | Computers & Internet
Radeon X800 XL AGP Card Installation Error
You should do a deep uninstall of all of the ati drivers present in your system... here are the instructions.
The "deep uninstall" starts by first uninstalling all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from ati.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are DONE!
Jul 08, 2008 | ATI Sapphire RADEON X800XL RADEON X800 XL...
Driver
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers (you will need to do this at native vga mode).
You should have downloaded the most recent catalyst drivers from ati or the manufacturer of your pc.
Apr 19, 2008 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Corel Print House Magic 3.0 for PC Logo
175 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
