Question about Poulan Garden
Spark plug location for Poulan 2300 - Poulan Garden
  • 285 Answers
Most likely to be found under the removable casing at the top of the chainsaw. The spark plug will have a black rubber spark plug boot which will identify its location. Remove the spark plug wire/boot to access the spark plug. The boot should just pull off. The spark plug will need the correct size socket to remove it.
Posted on Jun 15, 2009
2 Suggested Answers
  • 4088 Answers
SOURCE: will start but will not stay running poulan 2000
Check the diaphragm in the carburetor of each saw for hardness or cracking of the material. This is a common problem with older saws, but easily fixed by replacement. Check the fuel filter within the tank of each saw for being plugged--a problem that occurs when leaving old fuel mix in the tank for long periods. Hope this helps!
Posted on Jan 25, 2010
Cant locate spark plug for poulan 2400 2.3 c.i chain saw
remove the cover under the top handle its under there
Jun 08, 2012 | Poulan Garden
Poulan 2300 Firewood chain doesn't oil
She is long of tooth. Some oiler parts are NLA. Item 17 on the "Power Unit" print is the actual oil pump. Do not mistreat it; do not blow it out with air; they are no longer available.
http://www.ordertree.com/modelinfo/PWE/2300AV-Gas-Saw/75.2300AV-Gas-Saw.1.59.1.html
Please see this thread, post 5
http://www.arboristsite.com/showthread.php?t=120981&highlight=poulan+xxv+oiler
The *.pdf is your oiler. I suggest you read the entire thread. and save the *.pdf to your hard drive. HTH
Lou
Feb 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Will start but will not stay running poulan 2000 just changed spark plug thought it might help also have a 2300 will not take gas to carb just changed the fule line
Jan 24, 2010 | Poulan Garden
No Spark, plug is good
Hi
If you have a good plug in still no spark you will need to install a new coil.
Sam
Jan 07, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
What type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Sep 05, 2009 | Poulan Garden
Poulan push mower won't start
Remove the spark plug and pour a teaspoon of gas into the spark plug hole then replace the spark plug and it will start.
Aug 06, 2009 | Poulan "Poulan" Push Mower
Garden Logo
1,023 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
