Question about FUJIFILM FinePix JX250 Digital Camera
Outer body, battry door
Battry door is broken, want to replace.
  • 36 Answers
You should contact Fujifilm. They are your best bet for locating a replacement part. The Digital Camera Parts and Accessories phone number is 1-866-289-3854.
Posted on Mar 26, 2014
I need to replace my holden barina right outer door handle since it is broken
remove the door trim and inside at the handle you will see 2-3 nuts that hold the handle in the outer skin of the door.
Mar 25, 2014 | 1993 Suzuki Swift
I have a 2004 pontiac sunfire, door was hard to open, so I pushed it, now the outer door panel is coming off an I think some clips are broken
You mean inner door panel
The clips are avail on the internet,some in auto parts
stores & mostly at auto body supply wholesalers
But only in a box of 10 pc's
Jul 27, 2013 | Cars & Trucks
Broken outer glass
Please can you help to find a part number for outer door
glass or is any other outer door glass suitable for
AEG MCC3880EM I can fit in? Many thanks
glass , how much it would cost or is any other outer door glass suitable for
Dec 07, 2012 | AEG Ovens
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do you fix the door handel when it wont open from the ouside
the outer handle is connected to the lock with a steel rod. If the outer handle has broken or the clip that holds the rod onto that handle has broken, then thats what you need to replace. You will need to remove the inside door trim to access the locks and rods. Remove the door trim as best you can if you are unable to open the door at all and reach into the door to access the inner door lock rod. Pulling or pushing the rod should allow you to open the door and remove the trim completely.
If there is no obvious damage to the outer door lock, check where the outer door handle rod connects to the lock itself as the clips holding the rods in place can fail. If the clips have failed, replace them with new clips from the vehicle manufacturer..
Mar 10, 2011 | 1992 Buick Regal
Need repair part--battery door part has broken off and willnot stay closed
you will need to take it to the local service center, they will do the required work. mostly u will have to get your body changed as the lock that holds the battery cover is a part of the outer body of the camera
Apr 14, 2010 | Olympus FE-310 Digital Camera
My phone,s battry and internal stir is damaged
If it's just the battery which is damaged then you must replace it as no damaged lithium ion batteries can catch fire or even explode.
If the phone is damaged as well, then please explain more clearly what's broken.
Feb 15, 2010 | Samsung U900 Soul Cellular Phone
The outer panel of the drivers' & passengers' doors are loose at the bottom and make it difficult to open the door.
Take your car to a body shop or a dealership, they can pull off the body panels, find out why, and replace the broken pieces or parts. The dealership is always the better way to go even if they are a little more expensive because if they scratch your paint or break something they will make things right.
Sep 27, 2009 | 2006 Saturn ION
Have a 1998 S70 volvo and it has a broken right outer tie rod...
no not common when rackpinion was replace they should of replaced the outer tie rod
Jun 22, 2009 | 1998 Volvo S70
2033 kia sedona sliding outer door handle
take inside door pannel of,gently remove plastic sheet,and you will see door handle,un clipdoor lever and nuts,
Jul 12, 2008 | 2003 Kia Sedona
FUJIFILM FinePix JX250 Digital Camera Logo
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
