Question about Konica Minolta Office Equipment & Supplies
Minolta Copier Bizhub 1263/211Problem
Message displayed Machine Trouble C0070 call service
  • Konica Minolta Master
  • 1,297 Answers
C 0070 toner bottle mechanism defect.Remove the toner cartridge and clean using a vacuum cleaner the toner botle house and the sensor.
Posted on Mar 25, 2014
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 27, 2016 | Konica Minolta Bizhub C253 Copier
C163 on b52izhub c5
3B02,3B03,3B04 - IH malfunction.Try reset the error code:
Turn OFF the copier,press and keep pressing the Function key and turn ON the copier.Keep pressed the Function key until appaire the Trouble reset message on the display.Release the Function key ,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Dec 23, 2013 | Konica Minolta Bizhub C452 Copier
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
C dc00 konica minolta c351
CDCXX-trouble related to security.Try to reset:
Turn OFF the copier.Press and keep pressed the Utility key and turn ON the copier.Keep pressed the utility key and wait to Trouble reset message appaire on the display.(1-2 minutes.).Release the utility key and touch the message.Turn OFF the copier,wait 1 minutes and turn ON.If the error code displayed call the technical rep. from Konica Minolta.
Apr 06, 2013 | Konica Minolta bizhub C351 All-In-One...
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Mar 07, 2013 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub 363 error message c-2201
remove the toner bottle let machine thur its paces when it says install toner bottle install correctly
Feb 24, 2012 | Minolta Office Equipment & Supplies
LCD Display displays Error C0510 Can't do anything about it.
low temperature issue. There is a trouble reset procedure that should be performed by a Minolta tek
Oct 26, 2008 | Office Equipment & Supplies
Minolta CS Pro Error Code C0070
Turn on and off WITHOUT toner bottle inserted to reset to home position. If message comes back, the toner motor/drive gears are busted. Time consuming repair, be warned!
Dec 07, 2007 | Minolta Di3510f Bizhub Copier
100 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
