Question about Apple iPad Tablets & eReaders
IPad scanning line moving across screen
I was updating my relationship status on Facebook when a thick green line was running vertically across my screen. Can anyone provide some info on what this is? Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
I would like to help, but I just want to request a preview or screenshot of the green line in the iPad if possible.
Posted on Mar 24, 2014
  • Fi Foks Mar 25, 2014
    Hi, thanks for responding. I didn't get a screen shot, but will next time it happens.
Cannot get Facebook on my iPad.
Make sure all your software upates are complete and goto App store and try downloading app.
Apr 11, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Facebook comes up in blank lines
Go to Settings, select facebook, press uninstall or update, which option is available to you.
If uninstall, then the App will be uninstalled, after which you should re-install the app by going to App-Store and locate Facebook App there, to reinstall.
If Update, then you should select this option and lets the App update itself and try it Again. If problem still occurs, then uninstall as described above.
Mar 03, 2015 | Apple iPad 2
How to tell if Papa pear is connecting to my friends on facebook
Try logging out from Facebook from inside PPS, do a restart on the iPad (hold down Home and Power button together for 10 seconds) then start PPS and connect to FB. If that doesn't work, delete the game and reinstall it. (This is standard troubleshooting for most apps)
Jan 06, 2015 | Apple iPad 2 Wifi 16GB
Facebook comes on then goes out
This is usually a memory error. You may have too many apps open and need to close them.
Double click the home button to bring up all the open apps on your iPad. They will list in a line across the bottom of the screen. If you are on iOS7 or later you simply swipe the screen shot of the app upwards to close the app completely. Then go back to your home screen and open the app as you normally do. This should force the app to reboot and work as intended.
After closing all the apps you should then shut down the iPad completely. You can do this by holding the sleep button on the top edge for about 5 or more seconds. You will then see a slider on the touchscreen pop up that indicates you can shut down the device. After it is completely shut down, count to 10 and then press and hold the same sleep button on the top edge for 5 or more seconds to reboot the iPad. You can also plug it into your computer or charger at this point to force the iPad to turn on.
Sep 23, 2014 | Apple iPad Tablets & eReaders
How can I get my iPad to work vertically
Check to insure the side switch is on for screen rotation.
Go to settings, General. and untick LOCK Screen Orientation.
Jul 31, 2014 | Apple iPad 2 Wifi 16GB
My Facebook app keeps crashing, it will come on but goes out in secs.
Assuming this app is on an iOS device (Apple). Following these Several steps should resolve your issue, firstly quit the app entirely by using four fingers swipe up on the tablet, or press the home button twice, either step will show the active apps, find the Facebook app, then with a single finger swipe up, this step should see the app move upwards on the screen, quitting the app. Theis next step requires you to hold the power button and the home button at the same time, until the device shutsdown and the logo appears, then let go of both buttons allowing the device to start/boot completely. Locate your Facebook app, start it, does the problem still exist? If after the above steps you still have the same issue, you can delete the app, by placing your finger over the app & holding until the app jiggles and shows an "x" in the top left corner of the app graphic, touching the "x" will remove the app from your device, you can then re-install the app, finally you may simply need to check to see if the app needs to be updated, by opening the AppStore, and selecting Updates, if an update for Facebook is available for you it will show up here. I hope something within the information has helped.
May 19, 2014 | Apple iPad 32 GB WiFi Tablet PC
Ipad 2 has a transparent line moving across screen
have you tried a hard ware reset?
turn off device, then hold the power button on top and the home key (make sure its not plugged in also)
keep Holding both keys... you will see the apple logo appear, and then flash off, and then it will restart again. If you keep holding the home key and the power key, it will continue in this loop. Holding it until it reboots once should be enough though, then just turn it on and let it boot normally.
Your settings and everything should remain the same, this just will reset the hardware on the device. I have had issues with my iPad 2 with games lately, mainly random crashing, when I do this hardware reset, it usually fixes my crashing issue for a while.
Once again the steps are:
Shut off device, make sure it is unplugged
Hold the Power button and home key, until the apple icon appears and then flashes off.
Let the device turn on normally, let go of home key and hold the power button till the apple icon appears, and let it boot up normally.
Test the application, this may or may not work. But its def worth a try.
Mar 07, 2014 | Apple iPad Tablets & eReaders
Pixelated iPad screen
You have damaged the internal video chip and/or screen. If you have purchased the iPad less then a year ago you may still have warranty coverage but Im not sure if that covers drop damage. If you purchased Apple Care you should be able to get it fixed or replaced by Apple. You can also look up the status of your apple care agreement by entering your hardware serial# here:
Check Your Service and Support Coverage Your Service and Support...
Follow the instructions on the site.
Jan 26, 2014 | Apple Tablets & eReaders
IPad won't allow me to change Facebook users? We have two users and now can't switch between the two.
If you are having difficulties on the mobile site I would suggest downloading the free Facebook App for iPad from the iTunes store. You can touch the same 3 line symbol to open a side bar and Logout is at the bottom. https://itunes.apple.com/us/app/facebook/id284882215?mt=8
Unfortunately, if you are on the mobile site the only way to switch to the Desktop site is to open the left side bar.
If you are using the app, try deleting it, then reinstalling. You may also want to see if there is an update available which may fix it as well. If all else fails, use safari to try to use the mobile website.
Best of Luck!
Jul 10, 2013 | Apple iPad 2 Wifi 16GB
How to unfreeze candy crush game
Apr 26, 2013 | Apple iPad 2
Tablets & eReaders Logo
121 people viewed this question
Top Apple Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
John mullen
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
