Question about Samsung SCX-6320F All-In-One Laser Printer
Errore fusore errore fusone temperatura bassa
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 150 Answers
Hi , you are replace the printer fuser unit or fuser thermister
Posted on May 06, 2014
Model 2820. How do I solve engine error?
Try Engine test:
turn on device open tray 1 and load paper (1 is the manual feeder)
when you open tray 1 there's an engine-test switch, found it and press it
Engine error are also cause too much resistance from toner, fusor or gears. Remove toner and check that it roll with your fingers on gears, and do same with fusor (could be very hot warning - should be hard move it but not too much) and with printer off and fusor removed check if you can move any gear manually (this can be harder but will help you determine if it's board error or resistance cause a gear problem).
Any previous error happened with the printer can help to diagnose (jams, power off while printing...)
Sep 17, 2015 | HP LaserJet Office Equipment & Supplies
50 fusor error code for hp 3055 copier printer
Fusor needs to be replaced or error in Fusor section of main board
Jun 01, 2015 | HP Office Equipment & Supplies
50.2 fusor error
Hi Zaikow,
Whats the printers model?
Still, check the fuser and make sure its well held in place by the two tabs otherwise if the tabs are loose,the error will appear.
Hope this helps.Thanks!
Nov 25, 2011 | Office Equipment & Supplies
SALE ERROR TEMPERATURA FUSOR Y NO PASA DE AHI. AYUDA!!!!!!!!!!!!!!!
Ve aqui http://www.printersolutions.infored.mx/186810_Reparacion-de-Impresoras.html
Sep 15, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Cada ves que predo mi TOSHIBA e-studio202L me aparece error c440
tienes un problema en el area del fusor, lo puedes resetear siguiendo estos pasos:
1.- prende la maquina presionando 0 y 8. espera unos 5 segundos hasta que la copiadora haga un sonido y prenda en test mode
2.- escribe la numeracion 400 y presiona start.
3.- te debe de aparecer un numero de error, para resetearlo solo escribe 0 y dale set o start.
4.- apaga y prende el equipo normalmente y has pruebas funcionales.
si tu equipo sigue marcandote problemas vas a necesitar reemplazo ya sea de las resistencias termicas y el sensor de temperatura, algun fusible o alguna tarjeta controladora de alto voltaje.
Suerte...
Mar 15, 2011 | Toshiba e-Studio 232 Black and White...
ERROR DE IMPRESORA , TEMPERATURA FUSOR
que debo hacer ya es la segunda vez que sucede
Jul 24, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Caro esperto codice errore c0510 minolta dialta di 1610 sapresti come fare per sbloccare
Amico C0510 - fusione fallita (temperatura di fusione del basso anormale) temperatura del termistore fusione roll undectable rimane al di sotto di 120 ° ... controllare il fusore
May 24, 2010 | Konica Minolta Office Equipment & Supplies
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Samsung SCX-6320F All-In-One Laser Printer Logo
70 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
