SONY VIAO BGN SZ390P WO'NT RECOGNIZE CD/DVD DRIVE
RELOADED WIN XP PRO AND NOW SONY VIAO BGN SZ390P WO'NT RECOGNIZE THE DRIVE.
Whe I run thru hardware it says windows registry is not coorect error 19
  • fmkazimi Jun 15, 2009
    DID GOOGLE SURCH AND FOUND A SOLUTION. HAD TO EDIT THE REGISTRY IN WINDOW.
  • Joe Gornatti
    Joe Gornatti May 11, 2010
    So, did you succesfuly install XP and now it's giving you an error or during the XP setup it does not recognize the drive?
  • 192 Answers
You need to download the specific drivers for your drive from the sony web site. I am sure this is the problem. The site is set up to easily scan your computer and give you a list of drivers you need. I set up a Vaio two weeks ago, and loaded the drivers from the site for the disk drives, hard drive, monitor and sound card. Hope this helps. If you have reloaded all of the SONY drivers and it still does not recognize the drive, it sould be that it is not the drive that originally came with your computer.
Posted on Jun 15, 2009
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
My sony viao laptop is running win 8 preview but wont play my cd-dvd player
Windows is not detecting the dvd drive, try to update the drivers for the dvd drive.
Feb 21, 2013 | Sony VIAO Laptops (Laptop NOT Included)...
My Sony Viao laptop VGN CR353 DVD drive doesn't function!
Please note that this works only with the Windows drivers. ..... Reboot to make the changes active and permanent. .... After noticing that my laptop's CD/DVD drive started exhibiting the dreaded "choppy .... This is the same chipset I have on my Sony Vaio. ... Hi, the quick solution doesn`t work. Whats wrong? ...
winhlp.com › ForumsHardware, drivers -
Dec 06, 2009 | Computers & Internet
K9MM-V mB with DVD and CD drives .running XP pro .
make DVD drive the master, and Cd drive the slave. by set pin then have bios re search for them and try xp new hardware search with the new configuration
Jul 08, 2009 | MSI K9MM-V Motherboard
Optical drive sony viao vgn fs840/w won't register
try downloading the VIAO update tool
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS840W&upd_id=2775&os_id=7
this will ensure you have the latest software + drivers for your system.
problems with CD drives tend to be problems with the IDE drivers, so it may be a good idea to download the latest Chipset drivers either directly from sony (or using the tool above)
or downloading from the intel website
May 26, 2009 | Sony VAIO VGN-FS840/W Notebook
Won't boot
The error means that the computer is not seeing the hard drive.Hit F10 to get into BIOS and check that your hard drive is showing . If it is hit ESC and tell it to save settings. Then restart the PC.
If your hard drive does not show in BIOS, there is something wrong with it. It may be co-incidental that canceling the scan caused your hard drive to fail.
You can try to do an XP repair. Boot your XP cd:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstall the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 19, 2008 | Compaq Presario R3000 Notebook
My Device Manager doesn't recognize my CD/dvd drive.
its either yr hard ware is bad or that the drivers have not been installed. if u r using windows NT,XP then yr cd/dvd player is bad cos xp should installed most cd rom drives.
thank u
May 29, 2008 | HP Pavilion a705w PC Desktop
Toshiba DVD ROM SD M1302 driver
If you are using Windows 98, 98SE, ME, 2000, NT or XP, and have an ATAPI/IDE CD/DVD drive, there is no driver needed (see Toshiba statement I have posted below). Under no circumstances, if DVD is properly installed and functional, will you need ANY driver!
If your DVD drive is a SCSI drive, then it may need drivers specific to the SCSI card you have installed (see the specs/manual or website for your card). You may also need the Adaptec SCSI setup, available at this address:
http://www.adaptec.com/worldwide/support/suppbyproduct.jsp?sess=no&language=English+US&cat=%2FTechnology%2FSCSI+Software&fromPage=driverindex
or use this address if you have a LOGIC based SCSI card or device:
http://www.lsilogic.com/
Now, if you meet the criteria for the first paragraph I wrote, and your PC does not load the driver automatically (after a reboot or two) then you have a PHYSICAL or HARDWARE problem. Either the DVD drive is improperly cabled, improperly installed or defective.
Those are all your options. See below, from Toshiba website
good luck
http://sdd.toshiba.com/main.aspx?Path=ServicesSupport/DeviceDrivers
ATAPI CD-ROM and DVD Drivers
Toshiba's CD-ROM and DVD-ROM drives do not require any unique device drivers for Windows '95/'98/2000/XP/NT.
After installing your drive and re-booting, your system should recognize your CD-ROM or DVD-ROM. Win '95/'98/2000/XP/NT Operating Systems support all Toshiba ATAPI CD-ROM and DVD-ROM drives natively.
DOS/Windows 3.x Device Drivers
This device driver is to be used with DOS/Windows 3.x operating systems. Do not use this driver with Windows '95, Windows '98, XP or Windows 2000 unless you are going to use your system in the REAL or MS-DOS Modes. Device drivers for Windows '95, Windows '98, Windows 2000, XP, OS/2, and NT operating systems are provided with the installation or setup software of each operating system.
DOS ATAPI Interface Driver
If you prefer using DOS click the link below to download a MS-DOS ATAPI interface driver.
atapi.exe
SCSI CD-ROM and DVD Drivers
SCSI interface drivers are written for the SCSI card you are using in your system, by the SCSI card manufacturer. They are not specific to your Toshiba drive and are not provided by Toshiba. If during installation Windows can not find the correct SCSI software driver for your SCSI card and you do not have the software driver that came with your SCSI card, contact your SCSI host adapter manufacturer.
Adaptec SCSI Drivers
LSI Logic (Symbios) SCSI Drivers
DVD Viewing Software
Toshibas DVD drives require a third party software to be installed in your system to enable you to view DVD movies. If you purchased your drive as part of a kit, the software may have been included. The links below will provide some possible solutions should you not have this type of software.
Nero6 (Toshiba recommends)
Toshiba does not recommend nor endorse any of the following manufacturers software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
DirectDVD
Cyberlink PowerDVD
WinDVD
Media Burning Software
Toshiba's recordable drives require third party software to be installed in your system to enable you to burn media. If you purchased your drive as part of a kit, the software may have been included. The link below will provide some possible solutions should you not have this type of software.
Toshiba does not recommend nor endorse any of the following manufactures software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
NTI CD & DVD Maker
Gear DVD & CD-RW
Roxio Toast (Macintosh)
Easy CD Creator
Stomp Clinkn Burn Pro
Feb 24, 2008 | Computers & Internet
Windows XP not recognizing cds/dvds in my HP DVD640i
Most likely your CD-DVD burning software is corrupted. When that happens, the machine doesn't recognize the existence of the CD/DVD hardware. Clean up your machine, defrag, run a freeware registry cleaer-defragmenter (see C-net for a good one). Then Reinstall/upgrade your burning software (the Windows XP software is not sufficient) either from HP/Compaq, if it came with your machine, or the program website if you purchased it separately. You may find out which it is by using a marvelous freeware program called Belarc advisor.
Feb 11, 2008 | HP LightScribe dvd640i (DVD640I)...
Computers & Internet Logo
123 people viewed this question
Alun Cox
David Payne
David Payne
