Question about Saeco Coffee Makers & Espresso Machines
Aulika e05 the machine makes for 3 or 4 cups gret froth and then it doesent machine was serviced and descaled
  • 2039 Answers
SOURCE: water leaks during the descaling
it started to leak after the descaling and the water that leak is the water very hot you might have a leaky boiller in the descaling process calcium in the boiller melt and if you have bad seal =leak in the boiller. if you use a descaler product and if you use vinegar that might be y you have no steam vinegar remove calcium in little pieces and sometime those pieces block the machine descaler product melt the calcium thanks for using fixya pierre
Posted on Feb 08, 2008
SOURCE: EAM3500S will not froth milk ?
First, check to see if it will pump out steam without a ton of water. If it doesn't, don't use it.
Now, skim milk is terrible for it, the bubbles are too dry and flavorless. Use 2% milk or half-and-half. It should be cold (very cold). I put mine in the freezer in a steel frothing container for 5-10 minutes before use. Just barely submerge the wand (about .25") and turn on the pressure. It should sound like tearing paper (not like blowing bubbles through a straw). Do this until volume increases to around double (if you have a frothing thermometer, it should be around 100 degrees F). Now submerge the wand farther and tilt the cup to create swirling (this is called stretching & sweetens the milk). This should be done until the temperature is around 140-160 degrees F. Done.
If your machine is no good for steam, there's another way: Put milk into a steel cooking pot (I use a saucier for large groups) and put it in the freezer. When very cold (ice forming) put on stove. Whisk briskly while heating up on medium-high. It will create fine foam & stretch the milk at the same time. The bubbles will start big, but become finer as time goes by. I test by stocking my finger in & going until it feels nearly scalding & remove from heat. Just use a ladle for he milk & a spoon for the foam.
Posted on May 03, 2009
SOURCE: Frothing Milk: It seems whenever
It seems it is partially obstructed by backflowing dried milk protein. Use appropriate cleaning fluid
Posted on Dec 31, 2010
Here's what I did... with great success:
If you've cleaned all the milk deposits from around the o rings and you still have a problem then its almost certainly the milk spout (the little pipe that directs foamy milk into your cup)
Detatch the spout and get a 2.5 mm drill bit and use it to clean all the milk deposits out of the part that plugs into the lid. Rinse through with water to clean away all the bits of hard milk.
[If you put water through the spout before and after, you will notice a dramatic difference]
Doing this completely fixed the problem for me (I had about 3 years of milk build up in mine!).
Posted on May 02, 2011
diodeic
  • 1622 Answers
SOURCE: Delonghi ESAM3500 with not froth milk. Water will
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definitely the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black rings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism.
Hope this helps.
Posted on Sep 23, 2011
How to solve E05 problem on Saeco Exprelia?
I filled the water tank half with descaling solution (less diluted than normal - probably it was double or tripple strength) and restarted the machine several times. It kept on showing E05 each time, but it took in a small sip of the descaling, so I waited some ours and restarted it 3 times more. And repeated this for several times for 2 days. When I had almost given up, after 15-20 restarts, it primed and I could run a full descale. I forgot to weigh how much decaling it took in by each restart, that would have been nice to be able to post.
Jul 15, 2014 | Saeco Exprelia Automatic Espresso Machine...
Coffee maker will not prime.
E05 means "Water circuit blocked. No water in flow meter or flow meter not turning (jammed)".
Since I got it when I had not descaled for a month, I poured in tripple strength descale in the water container, and restarted the machine 3 times. Noticed that it took in a small gulp of the descale. Waited hours. Restarted 3 times again. Waited... and after about 20 restarts over 2 days. When I almost had given up it primed and was able to do a normal descaling.
I forgot to weigh how many grams of descaled it took in after each restart. That would have been nice for troubleshooting.
Apr 06, 2014 | Saeco Exprelia Automatic Espresso Machine...
Doesn't make enough steam
This usually happens when the machine needs descaling.Then we have more water than steam.
Mar 30, 2014 | Saeco Aroma Espresso Machine
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Can I use vinegar to descale my Breville single cup coffeemaker?
White wine vinegar is a great descaler as it can dissolve the white deposits. For kettles, fill them up and leave them overnight. Don't boil it, though - the vinegar will froth up and go everywhere. Afterwards, rinse the kettle thoroughly, fill with water and boil before using it again. Malt vineger can also be used as the malt only adds flavor
May 05, 2011 | Breville BKC600XL Coffee Maker
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Saeco royal digital - pressure problem
There can be some calcium in your rapid steam boiler, try to descale the machine and see if it help.
Apr 07, 2008 | Saeco Royal Digital Plus Coffee...
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
