Question about Samsung DVD-611 DVD Player
Dvd probelems with samsung DvD-611
I put a dvd or a cd in the dvd player it say," loading" THEN it says "No Disc" BUT i known the cd or dvd dont be mess up so how can i fix this problem and also i dont have remote to the dvd player so else can i fix the with out the remote
Re: dvd probelems with samsung DvD-611
I put a dvd or a cd in the dvd player it say," loading" THEN it says "No Disc" BUT i known the cd or dvd dont be mess up so how can i fix this problem....Kindly reply me
Posted on Jan 20, 2011
0 characters
3 Points
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
I have a samsung dvd-v4600...and when i put the dvd disc in it just keeps loading and will not load ..what do i do to fix this?
Does it do with original DVD or copied DVD ?.
if the original one works fine but the others not, your DVD may not capable of playing copy -R/RW discs..even though your DVD specs says: Plays DVD-Video, video-mode DVD-R/RW and DVD+R/RW, CD-R/CD-RW, MP3 CD, Kodak Picture CD, and JPEG image CDs, sometimes this happens due to bad recording of DVD .Try to use better recorded DVD or if possible use the original ones..
Thanks in advance for rating me..Regards
Oct 22, 2010 | Samsung DVD-V4600 DVD Player/VCR
It Loads but doesnt spin and said "no disc."
Try cleaning the lens with a DVD Disc Cleaner or Methylated Spirit and a Q-tip, rub the lens slowly in a clockwise motion, leave to dry and put in a DVD, if it doesnt work try a CD but make sure they dont have any scratches or dust on them, if a CD works ( or not ) then your lens is knackered.
Aug 12, 2009 | Polaroid Portable DVD Player PDM-0822BD
Dvd will not record
Hi and welcome to FixYa,
Initially, try to clean the lens using a CD disc cleaner. Additionally, verify that your blanks are either DVD-R or DVD-RW.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Samsung DVD-R130 DVD Recorder
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
When I load a DVD into the Samsung player, it says it's loading, about a minute later it states, "...can't display disc, check disc.
hi emiller,you might be playing a format not known or cannot be played on ur dvd player check if any original format (dvd) works on your player.
May 11, 2008 | DVD & Blu-Ray Players
DVD player says "no disc"
replace the player because laser lens is probably burnt out.
you can get a new player for 30 bucks at target or walmart
Jan 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung dvd home cinema system ht-ds110 not playing dvds
My initial IDM-1731 tells me no disc every time i try to play dvd cd please help me
Jan 06, 2008 | DVD & Blu-Ray Players
Samsung DVD-611 DVD Player Logo
187 people viewed this question
Top Samsung DVD & Blu-Ray Players Experts
Are you a Samsung DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
