Question about Hamilton Beach HB-P100N30AL-S3 - 1.1 CF Microwave Oven, White
Microwave won't start
When I try to start the microwave to cook I push the add 30 sec button and the display says 'do or'. There is nothing in the way and the door seems to be closed. The light is also on. what is wrong? How do I get it to start?
    Top Expert:
  • Hamilton Beach Master
  • 34,188 Answers
The door interlock may have failed.
Posted on Mar 24, 2014
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
When pushed, the 30 sec button says 3 minutes. none of the display buttons work.
Have you inadvertently programmed your microwave for "autostart"?
Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
Have you tried unplugging it for a few minutes?
This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Dec 26, 2009 | Emerson MW8107WA Microwave Oven
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
My microwave has 00:00 where the time or cooking mins should be displayed. I am pushing buttons and nothing changes. I can't use the microwave.
Unplug the microwave for 10 minutes and then replug-in. This will reset the unit.after that if it still behaves abnormally , Press cancel button for 10 seconds and then try pressing the timer adjust buttons.
thanks
Aug 31, 2009 | Sharp Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Hamilton Beach HB-P100N30AL-S3 - 1.1 CF Microwave Oven, White Logo
255 people viewed this question
Top Hamilton Beach Microwave Ovens Experts
Andrew Taylor
Andrew Taylor
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
