Question about Konica Minolta Dv710 O2xk Black Developer Bizhub 600 601 750 751 Lk
Bizhub 750, i put new developer, is there any setting that i have to do after this job?thx
  • sorin
    sorin Mar 26, 2014
    Thank you.
  • Konica Minolta Master
  • 1,294 Answers
After you change the developer enter in service mode press Utility key- Meter count- Details-Stop-0-0-Stop-0 -1press Counter select Special(optional)parts counter select Developer and reset the Developer counter value by pressing C.After reset the developer counter enter in Imaging Process adjustment mode select Drum pecularity mode and select Cartridge installation mode press the Star button.The process duration is 2-4 minutes.Whwn thw ok appears press Exit and return the copy mode,make a test page.
Posted on Mar 25, 2014
  • sorin
    sorin Mar 26, 2014
    Thank you.
2 Suggested Answers
resonatom
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
bizhub c252 how do you reset enter serial number
Posted on Mar 09, 2012
How to reset a password of bizhub 600-750
Which password the admin or the individual passwords Default admin 12345678 or 00000000
Go to:
Admin setting- Security setting -admin password
Oct 23, 2014 | Konica Minolta Bizhub 600 750 Image...
PROCEDURE CHANGE DEVELOPER KONICA BIZHUB 600
First clear the developer counter in service mode.
then remove the drum cart. remove developing unit. remove old developer. then run Auto max density. If you don't and make a copy or print you will have to replace the developer again
. recommend cleaning all toner around the drum and drum sensors requires removing drum be careful a nick on the drum will show up on all copies/prints
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
Service mode option which
Sir/Mam,
DID YOU CLEAR THE COUNTER FOR DEVELOPER IF NOT DO THAT FIRST BECAUSE the Machine RUNS ON THE COUNTER DATA!!!!!! after that Run 1. auto max density, 2.Auto LASER Diameter , 3. auto Gamma DOT 1 and Dot 2 then cartridge set
Jan 07, 2014 | Konica Minolta Bizhub 600 750 Image...
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
May 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
KONICA MINOLTA bizhub 601 problems
Does the machine work ok as a copier? Not as a Printer but a copier? if so then check you printer properties and insure that the paper is correct portrait or landscape, thickness correct draw check a different computer.
Dec 12, 2012 | Konica Minolta Developer 02xk Dv710 for...
My bizhub 600 is showing message warming up ready for next copy
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Mar 31, 2012 | Konica Minolta Bizhub 600 750 Image...
What is the proper way for replacing a new developer in bh501?
to replace the developer for a bizhub 362 take out the developer unit at both ends of the unit reove two screws on the left and right side carefully seperate the top half from the bottom half of the developer unit clean and hoover out the old developer you will need a toner vaccum for this job put the new developer into the unit put back the top of the umoit to the bottom of the unit put the srews that you took out back in put the unit back into the machine go into tech rep mode execute F8 quickly
job done
Jan 19, 2011 | Konica Minolta Bizhub 362 Copier
Konica Minolta Dv710 O2xk Black Developer Bizhub 600 601 750 751 Lk Logo
222 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
