Question about Thomson Lands Phones
Bz27922ge2 i want to change the ring and the manual
Panasonic kx-tsc901cid changing the ring tone
if you donot have manual then reset it to factory setting then after set your nunmer. setting
Dec 29, 2013 | Canon PIXMA MP530 All-In-One InkJet...
Want to change the ring setting to 6 rings before i goes to fax mode how to do it
See the "Changing the ring setting of the telephone answering machine" section on page 60 of this manual.
Jan 31, 2013 | Panasonic KX-FG6550 Plain Paper Thermal...
How to change rings from 2 to 4 rings
Open the menu, select "Ans. Setup" and then "Ring Time".Full details are on page 13 of the manual.
Apr 15, 2012 | Lands Phones
How the change the number of times a Samsung Impression rings
I dont think you can change the number of times it will ring, it all depends on what ringtone you have set i think. But you can look on the manual.
http://cellphone.manualsonline.com/manuals/mfg/samsung/a877_impression_1.html
www.usedcellphoneshop.com
Jun 02, 2010 | Samsung SGH-A877 Impression Cell Phone
To many rings for the machine to pick up
Unfortunately this machine does not have the facility to change the number of rings before it answers. The following extract from the manual describes how the number of rings is controlled:
Toll Saver Facility
Your unit has a Toll Saver Facility. This means your unit will answer call on the 4th rings if there are no new messages, or on the 2nd ring if new messages have been record. Therefore when you are calling your unit remotely you will know by the 3rd ring if there are no new messages. So you can hang up saving the cost of the call.
You can download the manual from here:
http://www.memorexelectronics.com/manuals/mph-1089.pdf
Apr 19, 2010 | Memorex MPH1089 Digital Answering Machine
Nedd to change fax ring pickup
Page 79 of the user manual shows you how to change a number of settings - see the link to user manual below
To set the number of rings before answering via the control panel
  1. Press Setup.
  2. Press Basic Fax Setup, and then press Rings to Answer.
  3. Enter the appropriate number of rings by using the keypad, or press the left or right arrow button to change the number of rings.
  4. Press OK to accept the setting.
The setup and user guide available here http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=ph&product=2512010&lang=en&
direct link to the user manual http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
HP 950 fax will send but does not receive faxes
It could be that your machine has been set to "no answer" in the number of rings setup area. See page 46 on how to change the number of rings.
It could also be set for a "distinctive ring pattern". See page 51 on how to change that setting.
User manual is here:
http://h10032.www1.hp.com/ctg/Manual/bpu05029.pdf
Jan 21, 2009 | HP PSC 950 All-In-One InkJet Printer
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Dec 04, 2008 | Panasonic KX-T7630 Corded Phone
Lands Phones Logo
22 people viewed this question
Top Thomson Lands Phones Experts
george  peters
george peters
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
