Question about Thomson Lands Phones
Bz27922ge2-a change the ring
When somebody rings sometimes it only rings once then goes silent
Go to Settings > Sounds > Change the settings to Ring+Vibrate or Ring Only or Vibrate Only
I guess you have by mistake changed the settings right now to Ring Only Once and hence it rings just once and then vibrates. If there is not settings icon and no sounds option you can check if you have Profile as option as you can change it accordingly in the profile you are using. Hope this helps. Good Luck
Mar 08, 2013 | Motorola Mobility Defy Cell Phone
Want to change the ring setting to 6 rings before i goes to fax mode how to do it
See the "Changing the ring setting of the telephone answering machine" section on page 60 of this manual.
Jan 31, 2013 | Panasonic KX-FG6550 Plain Paper Thermal...
Problem with 2001 Prizm '01 Prizm 5 spd: piston ring change possible without pulling engine (Toyota 1zzfe) Posted by Guest on 11/29/2012 Details '01 Prizm 5 spd: piston ring change possible w
If you unbolt the con rod bearings and push the piston out of the bores, then the rings can be changed but the bores MUST be honed at the same time.
Oct 28, 2017 | 2001 Chevrolet Prizm
Change ring tone
How to Change the Ring on a Motorola V360
When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
Instructions
1.Press the "Menu" key on your Motorola V360 and click "Settings."
2.Click "Ring Styles" and select "Style Detail."
3.Highlight "Calls" and press the "Change" soft key.
4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
5.Press the "Select" soft key to choose the ringtone.
6.Press the "Back" key to set the ringtone on the Motorola V360
Read more: How to Change the Ring on a Motorola V360 ' eHow.com http://www.ehow.com/how_8468915_change-ring-motorola-v360.html#ixzz1XEda3gRH
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial-----
Thank you for choosing fixya
Roger
Sep 07, 2011 | Motorola Mobility V360 Cellular Phone
SINCE NEW , UNABLE TO CHANGE RING TONE. IT ONLY
Under settings menu touch, more, applications, voice command, call alert. Change to ring only. Hope this helps.
Aug 05, 2009 | LG Xenon GR500 Cell Phone
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Change number of rings
To change # of rings you have to go into programing OK press feature * * on the main set and config (266344) then the password admin (23646) this goes to terminals and sets hit show and enter the set you want to change go to capabilities this will allow you to chang # of rings on that set
Mar 17, 2009 | NorStar Meridian M7310 Phone
M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Mar 04, 2009 | NorStar Meridian M7310 Phone
MOTO PEBL MESSAGE AND RING TONE
i think this is what you're going for...Go to SETTINGS, then RING STYLES. Whatever ring style (ie, vibrate, silent, vibe & ring, vibe then ring, loud, soft), underneath is the detail for it, which you can then change (bottom right of screen).
So right now my phone is:
"Style: Vibe & Ring" and underneath that is "Vibe & Ring Detail"
Under the details, you can change your ring tone by scrolling down to the "Calls" option and choose change (bottom right of screen). And to change your message tone, just go to "Messages" and then change (bottom right of screen).
Hope that helps!
Apr 08, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Lands Phones Logo
35 people viewed this question
Top Thomson Lands Phones Experts
David Burbee
David Burbee
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
