Question about Garden
No power mower starts no problem check carburettor seams ok on full throttle no power
    New Friend:
  • 10 Answers
Did you check the throttle cable linkage to the carburetor? There is a retainer for the throttle cable near the carburetor. This will sometimes come loose and even though you move the throttle lever forward it may not be moving the throttle cable at the carburetor.
Posted on Mar 25, 2014
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
May 30, 2016 | Toro Power Lawn Mower
My 2 stroke weed eater starts, runs full throttle for 20 seconds then bogs down. Im no mechanic. Please help!
Stuck throttle. See if you can check that the speed control is moving the thing on the end of it called a carburettor. Could also be an air leak in the thing that join the carburettor to the motor. called the inlet manifold.
If all else fails, just take it to a garden machine repair shop.
May 23, 2016 | Garden
It idles but will not run at full speed
Two things to look for - exhaust blocked. or aircleaner blocked.
another thing check to see if throttle linkage is actually opening the throttle in the carburettor.
Jul 25, 2015 | Garden
Snow thrower doesn't start up!
If you have a spark at the plug (you have checked?) it's probably fuel blockage. Check all lines, fuel filter and carburettor are clean, use a carburettor cleaner spray to get all the gum out.
Feb 23, 2014 | Garden
Zero Turn Lawn Mower shakes on full throttle
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 14, 2017 | John Deere EZtrak Z225 Zero-Turn Riding...
Craftsman ys4500 mower-- starts great and runs ok at low speed but at full throttle sputters and pops and of course loses power
sounds like your choke is not opening up all the way fast easy test,take a sharpe pen and mark priar adjustment on choke cable. next; remove cable from carb,then hold chokeopen start give full throttle{no difference} carb kit
Oct 22, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Motor stops after running for about an hour
sounds lie it is getting hot if aircooled /check around cyl. head finns for grass and dirt and not runnin on full throttle the way it is designed
Oct 21, 2012 | Garden
My srm3800 runs but when itry to use it it seems to cut off like not geting fuel it idle go but it will cut off aftet I give it gas
Check there are no kinks in fuel line.
Make sure that the air filter isn't blocked.
Check the throttle cable is operating the throttle plate in the carburettor ok.
Ensure chain isn't too tight.
The carburettor should be a tight fit on the air inlet manifold.
It's possible that some of the jets could be blocked in the carburettor. You can try and clean these with compressed air but ensure you remove any seals gaskets, springs on the diaphragm pump , primer bulb etc as they can be damaged by the pressure.
If the the choke normally disengages when the throttle trigger is squeezed, check this is working ok.
May 08, 2011 | Echo Garden
5HP Honda (HRU215) mower hard starting power loss
Either the choke isn't operating fully or there is some dirt in the carburettor. Check the choke first by putting the throttle lever full to the start position, the see if you can still pull the inner cable further at the bottom end. If you can, then you need to undo the clamp at the engine end and pull the outer cable back a bit before reclamping it in the new position. If that isn't the case, you will need to dismantle and clean the carburettor - probably a job for your local dealer..
Sep 07, 2009 | Toro Lawn Mower With Toro Power Tools
Starting my petrol mower
depending on age of machine set the throttle to maximum revs,and pull the starter cord but newer models have a primer button located on carburettor which is locked just under air filter (black or red colour) push it three times( you should hear it inject fuel) and then pull starter cord,some of these engines have a pre-set throttle ,main concern is that if it has not been used for some time you will need to clean carburettor out,replace diaphragm and remember to use fresh fuel(not older than 90 days) this should cure your problem
Mar 22, 2009 | Garden
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
