Question about Cycling
Reset procedure I have a plan printer oce colour wave 300, I just want to know if it is possible to reset the message "maintenance tray" without having to replace the maintenance tray
mitpatterson
  • 74 Answers
SOURCE: CLP-300
The only way to reset it it to buy oem cartridges because it only lets you use the starter tanks once, after that they must have chips
Posted on Feb 24, 2008
  • 2712 Answers
SOURCE: reset maintenance interval message
try this: 1. insert key 2. press and hold left button 3. turn on ignition and let it cycle through its check 4. turn key off 5. release left button.,
Posted on Nov 10, 2008
Regaltime28
  • 3 Answers
SOURCE: NEED TO RESET MAINTENANCE MESSAGE
Turn the printer off. Press and hold the select and return buttons while powering on the printer. Release the buttons when the display shows "Perform Self Test". The printer will continue to boot-up. When ready the display will show the word Config Menu. Then press the menu button untill you see the Reset Maintenance Count option. Then press the select button. The reset command shows on the second line of the menu. Press the select button again to reset. Now press the menu button untill you see the Exit menu and press select. The printer will now automatically reset itself and boot up ready to print.
Posted on Jun 02, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Can you clean maintenance cartridge and resume printing on error
hELLO THERE:
Yes you can clean the tray you may have to remove some items to be able to clean the whole tray but if you take rubbing alcohol and a eyeliner applicator you will be able to clean most of it. ok
best regards mike
Posted on Aug 03, 2009
manuel-d
  • 5 Answers
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
Posted on Nov 16, 2009
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8505,i want A Solution
The NTC 2 is probably shot. These are ceramic coated thermistors and extremely fragile. I would recommend calling an authorized Oce technician to get this replaced.
Mar 10, 2017 | OCE Office Equipment & Supplies
Does anyone know what error code 450011 /printer/id6 means on an OCE color wave 500?
Imaging Device 6 is faulty. It will need to be replaced. Be warned, this is a rather expensive part.
Jan 26, 2017 | OCE Office Equipment & Supplies
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Our Oce Plot Wave 300 is going through toner very fast. The toner waste bottle is supposed to last through two toner bottles but fills up in less than one bottle. The OCE technician has looked at it but...
Dear
the service engineer is right, Pl. check the resolution of the printer, next check the toner cart. if possible try disconnect the ground connection to the doc.blade.
Thanks.
Mar 03, 2015 | Office Equipment & Supplies
Oce colour wave300 has an error 4533.how to solve?
Dear sir;
Let's go to reset the fuser error first. the procedure is;
1st turn power off then turn it on while holding down the "utility/counter" key, the touch the " trouble reset " when " OK " display then turn power off, wait for about 15 sec. then turn it on .
hopefully you enjoy with it.
Nov 25, 2014 | Office Equipment & Supplies
My oce colour wave 300 have an error 4533.
This sounds like you may have a wifi or wireless connection issue. Try reinstalling the printer and drivers and see if this resolves the issue.
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
OCE Plotwave 300. Error Code 8515\printer
The middle NTC in the fuser is broken. These are ceramic thermistors and extremely fragile. Only replace if you know what you are doing. Otherwise call your Oce technician.
Mar 11, 2012 | OCE Office Equipment & Supplies
I have a Brother MFC-9440CN Laser Printer -reinstall tray message
Rule out the software solution: is the document being printed of the same size of the paper in the tray? If not, you'll get a spurious tray error every time you print and then e.g. someone else prints another document with a different format. See Control Panel > Printers > Properties > Tray for this.
Then the hardware/firmware options: there could be either some dust or grit in the tray sensor, so that it doesn't "feel" the tray until it gets nudged, or the chassis (or maybe the tray) got slightly deformed and no longer properly activates the sensor. This is a white dot inside the tray slot on the bottom upper left; try blowing some compressed air on it. A McGyver solution to a warped chassis can be to apply adhesive tape on the facing part, so that it is thickened and improves contact with the sensor. Not really recommended of course, and the tape is bound to come off or wear out, and maybe jam the sensor even worse, sooner or later.
A replacement tray kit may cost anywhere from US$ 150 to US$ 300 depending on source.
Another possibility is that the tray counter has reached end-of-life. Press # 72 and check whether the page count is 288,888; in this case there's a firmware problem and I am not sure of the solution (it's known as the "Brother 288,888 page count problem"). This is unlikely - I don't know that firmware ever got in the 9440. But checking costs little.
I quote the reset procedure for end-of-life reset -- use wisely.
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
Press 3 and 9 at the same time in the ready status on power on.
The “Reset Menu” will appear on the LCD. Choose applicable periodical replacement part with the arrows. Accept with OK. Press 1 to reset the counter, or 2 to quit without saving. STOP to exit menu.
WARNING: using the machine with an end-of-life'd component may damage the machine, not only that component.
Hope some of this helps. Let me know how it goes...
Mar 24, 2010 | Brother MFC-9440CN Laser Printer
80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Jun 11, 2009 | Lexmark T522 Laser Printer
Cycling Logo
135 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
