Question about Cycling
How to reset maintenance tray manually
I have a plan printer oce colour wave 300, I just want to know if it is possible to reset the maintenance tray message without having to replace the tray ? any help would be appreciated
SOURCE: Replace Transfer Roller
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Posted on Jun 11, 2008
  • 2712 Answers
SOURCE: reset maintenance interval message
try this: 1. insert key 2. press and hold left button 3. turn on ignition and let it cycle through its check 4. turn key off 5. release left button.,
Posted on Nov 10, 2008
SOURCE: Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
Regaltime28
  • 3 Answers
SOURCE: NEED TO RESET MAINTENANCE MESSAGE
Turn the printer off. Press and hold the select and return buttons while powering on the printer. Release the buttons when the display shows "Perform Self Test". The printer will continue to boot-up. When ready the display will show the word Config Menu. Then press the menu button untill you see the Reset Maintenance Count option. Then press the select button. The reset command shows on the second line of the menu. Press the select button again to reset. Now press the menu button untill you see the Exit menu and press select. The printer will now automatically reset itself and boot up ready to print.
Posted on Jun 02, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Can you clean maintenance cartridge and resume printing on error
hELLO THERE:
Yes you can clean the tray you may have to remove some items to be able to clean the whole tray but if you take rubbing alcohol and a eyeliner applicator you will be able to clean most of it. ok
best regards mike
Posted on Aug 03, 2009
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8505,i want A Solution
The NTC 2 is probably shot. These are ceramic coated thermistors and extremely fragile. I would recommend calling an authorized Oce technician to get this replaced.
Mar 10, 2017 | OCE Office Equipment & Supplies
Does anyone know what error code 450011 /printer/id6 means on an OCE color wave 500?
Imaging Device 6 is faulty. It will need to be replaced. Be warned, this is a rather expensive part.
Jan 26, 2017 | OCE Office Equipment & Supplies
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Our Oce Plot Wave 300 is going through toner very fast. The toner waste bottle is supposed to last through two toner bottles but fills up in less than one bottle. The OCE technician has looked at it but...
Dear
the service engineer is right, Pl. check the resolution of the printer, next check the toner cart. if possible try disconnect the ground connection to the doc.blade.
Thanks.
Mar 03, 2015 | Office Equipment & Supplies
Oce colour wave300 has an error 4533.how to solve?
Dear sir;
Let's go to reset the fuser error first. the procedure is;
1st turn power off then turn it on while holding down the "utility/counter" key, the touch the " trouble reset " when " OK " display then turn power off, wait for about 15 sec. then turn it on .
hopefully you enjoy with it.
Nov 25, 2014 | Office Equipment & Supplies
My oce colour wave 300 have an error 4533.
This sounds like you may have a wifi or wireless connection issue. Try reinstalling the printer and drivers and see if this resolves the issue.
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
OCE Plotwave 300. Error Code 8515\printer
The middle NTC in the fuser is broken. These are ceramic thermistors and extremely fragile. Only replace if you know what you are doing. Otherwise call your Oce technician.
Mar 11, 2012 | OCE Office Equipment & Supplies
Oce plotwave 300 error maintenance and troubleshooting manual
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
Jan 27, 2011 | Office Equipment & Supplies
Oce tds 800 how do you reset the counter for maintenance and part
hi
you have to go into service first
you have to log on in SDS
WITH user :oceservice
pASSWORD:675756
And there on consumbeles you have to reset by
pressing 0 / enter and than egnoladge with the green V on top
good luck
Yaacov
Mar 11, 2009 | OCE Office Equipment & Supplies
Cycling Logo
89 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
