Question about Whirlpool Dishwashers
Whisper quiet plus
Can't figure out how to stop dishwasher from tipping out from cabinet with the door open and loading racks out. bought Granite Grabers but there was no place to attach them to
  • 957 Answers
There should be two thin metal tabs on top of dishwasher that extend out and attached to the underside of counter top. They may have been bent back or they are broken off
Posted on Mar 26, 2014
SOURCE: dishwasher tils when door is open because the bracket is roken
There is now a universal dishwasher bracket for just this problem called E-Z DISHWASHER BRACKET. It is available through Braxton-Bragg or ask for it at a local granite fabricator. It is very simple to use.
Posted on Oct 30, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
SOURCE: how to unlock the child lock
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Posted on Feb 20, 2010
SOURCE: dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
Posted on Aug 06, 2010
KitchenAid Whisper Quiet Plus dishwasher Location of serial number
Usually, the sticker is located on the inside edge of the door on either the left or right side--you have to open the door to see it.
Aug 19, 2015 | KitchenAid Dishwashers
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
Dishwasher was not installed but only slid under counter so now it topples over. I have no installation clips
Your dishwasher may have a "side mount" and you may be able to screw it into the sides of the cabinet, if not, you will need to find out how to attach the brackets to your dishwasher (they usually slip into a groove in the top of the dishwasher, bending the tab over once slipped in will prevent it from coming out again.) If the brackets are for another dishwasher, you will need to order the correct brackets for yours.
Oct 07, 2012 | Magic Chef Built-In Dishwasher -...
How I prevent the dishwasher from tipping? I have granite countertops so I will need to stabilize without clamping to counter?
Hello Mariebyrne, Solution 1: Call granite fabicator to mount dishwasher to granite top. 15 mins for them solution 2: Check sides of dishwasher for cabinet mounting (side mount). Open door to diswasher look at each side (in front of the door seal) about halfway down there will be some small round button looking plugs. If you see these plugs the mounting brackets need to be moved to the side position.the dishwasher will need to be pulled forward about 6 inches.after the brackets are moved position the dishwasher to where you want it. Remove plugs and screw in to cabinet. Replace plugs and your done. Hope this helps
Sep 17, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
I have a new GE Profile dishwasher and granite countertop. How do I attach it so it doesn't tip. I can't use the tabs at the top as the granite is right there. Any help?
Open door and look for removable hole cover along left and right side, several inches down from the top. Use a wood screw to secure the side of the dishwasher to the cabinets there, then replace the hole covers.
Mar 21, 2011 | GE Profile PDW9880NSS Stainless Steel...
Mounting my dishwasher to granite counter tops. Granite Grabbers last about a week before they loosen up
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Oct 21, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
I have granite countertops< so i have to install the clips on the sides of the dishwasher instead of on top. however the dishwasher has no holes with plugs
If you can't find any place on the sides to mount the clips then you can take a piece of wood that matches your cabinets and fasten it to the opening in you cabinet for the dishwasher so you will have somethink to mount the washer to. Make sure your washer is level so you can figure out the gap size at the top, then pull the washer out and mount the wood to the cabinet. You could call the guys who installed the counter tops and see what they would or could do, but I wouldn't drill into the granite myself
Jan 07, 2010 | Dishwashers
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwasher tils when door is open because the bracket is roken
Sep 11, 2008 | Viking DFUD042 Built-in Dishwasher
Dishwashers Logo
49 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
