Question about Dell Inspiron Mini 10 Notebook
On my Dell inspiron mini only the 5 & 6 number keys work all the others wont
The 1,2,3,4,7,8,9,0 do not respond only the 5 and 6 will.The number keys are all along the top of the keyboard not in a pad.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
You can use a sharp flat screw driver thin open all that letter dn clean it with eraser
Posted on Mar 24, 2014
  • 899 Answers
SOURCE: number lock won't turn on
When enabled, this allows the user to type numbers by pressing the keys on the number pad, rather than having them act as up, down, left, right, page up, end, and so forth.
in bios is where you can set number lock to enable at start up
so restart and enter set up(bios) and change it to lock numbers at start up
if you need more help just let me know
electech
Posted on Oct 23, 2008
taran_2005
  • 10515 Answers
SOURCE: Dell Inspiron E1505 Keypad problem
Refer to the link that shows the way to solve this issue :
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
Hope u could fix it urself :)
Posted on Nov 13, 2008
RSBennett
  • 54 Answers
SOURCE: fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Posted on Mar 10, 2009
fslahmed
  • 127 Answers
SOURCE: Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
Posted on Jun 01, 2009
shynysaxena
  • 166 Answers
SOURCE: Dell Inspiron 1525 #keys
Its a keypad problem. For solving this problem, simply take out these keys out by pulling them outward and then clean the socket-type granule below it. And then again replace the keys to their location. Surely these keys will start working.
Rate this solution if it was helpful to you...
With Regards,
Shyny
Posted on Jun 20, 2009
Factory settings restore on dell inspiron 1525 windows vista
Resetting a Dell Inspiron to the factory settings allows the user to restore the Dell Inspiron to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Get the step-by-step how to guide..http://technical-support-squad.blogspot.in/2012/08/dell-inspiron-how-to-factory-reset.html
Feb 12, 2012 | Dell Inspiron 1525 Laptop
When i turn on my dell inspiron mini screen to log in appears but my keyboard is not responding to let me log in -- help!
Almost sounds like the keyboard has gone bad. Try this: remove the battery and power cable.
Wait 30 seconds or so and put the battery back in. It may work now.
Also, when the system starts up, can you hit the F2 key to get into setup (at least I think it's the F2 key). If so, you may be able to load the BIOS defaults and it will work again.
Otherwise, you are looking at a repair job.
Mar 26, 2011 | Dell Inspiron Mini 10 Notebook
I have a Dell Inspiron Mini Laptop 1012, how do you set it to factory seting?
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart. 2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears. 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter. 4. Specify the language settings that you want, and then click Next. 5. Log in as a user who has administrative credentials, and then click OK. 6. Click Dell Factory Image Restore. 7. In the Dell Factory Image Restore window, click Next. 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition. 9. Click Next. The computer is restored to the default factory configuration. 10. When the restore operation is completed, click Finish to restart the computer.
Jan 05, 2011 | Dell Inspiron Mini 1012 Netbook...
I have a dell inspiron 1420 laptop. its keyboard is not working. none of its key respond on clicking. it tells me to reseat the keyboard. how to solve the problem? if to reseat, how to do it?
1. check the driver, reinstall & try.
2. check with a external key board. if working fine then ur motherboard is OK.
3. open the keyboard & clean the dust in the keyboard cables and motherboard connector.
4. if still not working ur keyboard might need replacement. check for any liquid spell on keyboard.
5. for replacement contact DELL customer support.
Aug 17, 2010 | Computers & Internet
Loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Jun 10, 2010 | Dell Inspiron Mini 10 Notebook
Fomating dell inspiron mini 10
You can make a bootable USB stick with everything you want and boot from it.
Stelios.
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 1525 #keys "5" and "6" unresponsive. All others respond.
With Regards,
Shyny
Jun 20, 2009 | Dell Inspiron 1525 Laptop
Fn key on dell inspiron 1501 keyboard not working
Hope this helps.
Mar 10, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron Mini 10 Notebook Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
