Question about Fujitsu Siemens Computers & Internet
We have fujitsu siemens model v2030d .there are problem in monitoring black nothing on screen plz hlp
Plz tell me more about laptop
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
Try clean the ram with eraser or replace it
Posted on Mar 24, 2014
MDoe
  • 156 Answers
SOURCE: FUJITSU SIEMENS AMILO PRO V200D
Hi
It sounds like Drivers for the Video card is not loaded properly.
What is the current screen resolution?
Are you able to increase the resolution to say 800 x 600 pixel or preferably 1024 x 768 pixel?
If the current screen resolution is 640 x 480 pixel and you are unable to increase resolution to the above pixel levels, try updating Windows Drivers for your video card.
AMILO Pro V2000 Display - Intel® 82852/82855 GM/GME Graphics Controller Family (Intel® 852/855 Chipset Family) (WinXP, W2000) Version: 6.14.10.3792.
Directly download - http://support.fujitsu-siemens.com/download/ShowDescription.asp?SoftwareGUID=325da0bd-fe5f-41e6-84d9-d628c5411188&OSID=665F4A20-6E31-43C3-82C2-D98CE773007C&Status=True&Component=Intel%20855GM
Regards
Mike
Posted on Mar 27, 2008
  • 101 Answers
SOURCE: fujitsu siemens amilo pro keyboard replacement
Hi is that you want to replace the existing keyboard from your mom's laptop ? if so right above the keyboard you will find a removable plastic panel (it is fragile breaks very easily so be carefull ) which would secured in place with snap on plastic locks or 3 screws would be securing it in place which you can see on the rear of the laptop , if the battery compartment is under the top portion then remove the battery you can see these screws . In any case please take your OWN TIME TO ANALYZE and only then attempt this. If you are succesfull in doing this then remove the other screws visible that holds the KB in place and lift up the KB slowly because the connecting cable is flexible PCB and you could easily TEAR IT OFF if you pull hard . The Connector also needs lot of attention - very thin and small release the side catches by lifting it with a watch screw driver very slowly else you will end up breaking it . If you have come to this stage GREAT replacing KB is reverse of all this procedure.
Posted on May 10, 2008
  • 202 Answers
SOURCE: could someone helpe me with Amilo Pro V2030D sound drivers
Go to the link below:
http://support.fujitsu-siemens.com/com/support/downloads.html
Enter the requested information. It will take you to the download page for drivers. Select the ones you need and download and install them.
Good luck and let me know how it works out.
Posted on Feb 08, 2009
drifterK
  • 4924 Answers
SOURCE: Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Posted on Jan 30, 2010
  • 357 Answers
SOURCE: I have Fujitsu Siemens (
If you Google the make and model of your machine there are loads of places to obtain your drivers from, even going to the Fujitsu site should supply them. Have you tried rebooting in "Safe" mode (normally the "F8" on boot up) it might just sort it.
Posted on Feb 04, 2011
Testimonial: "thanx alot"
Blank screen
sounds like you have a bad lcd screen, try and hook it up to an external monitor and if you get display you need a new screen.
Aug 16, 2013 | Fujitsu Siemens Computers & Internet
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor does...
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Sep 29, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
My Fujitsu-Siemens Lifebook S7110 display going black time to time. It's coming back after restarting and it's working great with external monitor.
The display may be going black because of IC's getting heated up,contact ur Provider and get the screen replaced if using an external monitor is irritating
Dec 20, 2009 | Fujitsu Siemens LifeBook S7110 Notebook
Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Aug 08, 2009 | Fujitsu Siemens LifeBook T1010 Tablet PC
How to use two screens concurrently.
Plz you can see the right side of your laptop then sow a port,this port is external monitor.connect Monitor cable,then you can use it.
Apr 03, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Could someone helpe me with Amilo Pro V2030D sound drivers
Feb 03, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
To fix mouse pad
Before you dismantle your laptop, check that the pad isn't disabled. Go to control panel and click on Mouse, the mouse pad configuration should be in there. turn it on. also look for it in Device manager (right click on my computer, go to properties) make sure the mouse pad has a driver loaded and it's working.
Feb 25, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
166 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
