Question about Karcher Garden
Hose keeps popping off... Brand new. Is there a method of starting up ? I attached the hose... On goes karcher...On goes hosepipe tap....the plop, off comes the pipe ? What am I doing wrong. It is attached to a black plastic thing with ring,
  • 25 Answers
The best thing is to get a complete pair of quick couplers. One male one female and replace the ones you currently have. Stick the male on the washer the female on the hose and as they are the same should be able to hold under the pressure of water.
Posted on Jun 17, 2014
  • 92 Answers
SOURCE: karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • 10 Answers
SOURCE: We have connected up the
Most washers when turned on will build up pressure and then go into bypass(shut off) untill trigger is pulled,
Posted on Apr 22, 2009
  • 72 Answers
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
  • 88 Answers
SOURCE: Karcher K2.19 Pressure Washer - Hose Coming Off
yeh this is what happen if you remove the yellow cover and you will see the metle u clip that is all that part holds on. you will needa new one from your local pressure washer supllier
Posted on Jan 20, 2010
spraydoctor
  • 97 Answers
SOURCE: karcher 2.56 keeps pulsing on and off whenever high pressure nozzle is attached. I have tried different nozzles and same thing is happening. when i press the lance without any attachment it works fine
If this PW has never worked properly -- it is possible that the seller sent the wrong pressure nozzles. All pressure washers have nozzles that are matched to the flow-rate and pressure of the machine. If they sent Nozzles that were really supposed to be for a machine of lower flow rate (smaller orifice nozzle) this would cause exactly the problem as you are describing it. This is because the electric motor does not have sufficient horse power to force the xxGPM out the smaller hole, so the motor surges and stalls, repeatedly.
Another possibility: Try a different electrical plug outlet. It is possible that the motor is not able to draw enough current from your plug. Sometimes older house plugs, because of the way they are installed, will not provide a good, solid 15 amp circuit like it should. As the motor comes under a load (i.e., when you install pressure nozzle) it draws more current to feed the work. So try a different plug and be sure it's on one of your circuits that is not loaded with other household items like the refrigerator, microwave oven, etc. The little washer all by itself will pull close to 15 amps, which is the max capacity of older home circuits.
Last, Look for the unloader valve. This is device that allows the water to go into a by-pass loop when the trigger is not pulled. It sounds like the unloader could be out of adjustment. Counter-clockwise will lighten the spring / Clockwise will tighten the spring. Toy with different adjustments -- ccw 1 complete revolution/test for improvement. Repeat. (it should have a plastic handle on top of it that can turn either direction. But look at it first, as there may be a "set" nut holding in one place.)
Posted on Mar 03, 2012
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
The hose keeps popping out when you put the water on
the house end or the high pressure end?
Mar 29, 2014 | Karcher Garden
New k 3.190, motor does not work
So I just read this very helpful posting.
I dismantled my Karcher 3.190 plugged in the hose and spotted a leak coming from the inside on part of the casing?. When I switched on the pump, it started gushing. It's just out of warranty!
Do I,
A: junk it and slam Kirchner via social media or is it
B; fixable at a reasonable cost.
Opinions, witty replies, and solutions always welcome.
Regards
Wil
Mar 17, 2013 | Karcher Garden
Have a brand new karcher 3000 pressure washer with a honda gc190 motor. Fired it up today, ran about 5 minutes then died. Noticed that gas was coming out of a hose that is attached to the bottom of of...
It sounds like the carborator has a drain ****, with a hose attached so it doesn't get gas all over everything. The reason to do this is to drain condensate once in a while. See if you can find a small drain valve and check to see if it is closed. Then add some more gas and wash away!
Oct 29, 2011 | Karcher G3025OH Pressure Washer
Hose out of the karcher unit blows off
Sounds like you need a new hose if it keeps blowing off the unit, see attached link to purchase the hose.
http://www.wmpcs.com/index.php?main_page=product_info&cPath=81_55_58&products_id=286
Oct 29, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Why dose my Karcher K2.35 keep blowing the gun hose off?
There is a good chance you are missing the black plastic clip that holds the hose into the trigger gun. If you look at where the hose goes into the gun there should be a flat slot where a black plastic clip would slide in and keep the hose into the trigger gun.
Oct 24, 2010 | Karcher 2500 PSI Pressure Washer
Bought suction hose for karcher in order to use water from bucket. Have attached hose but there is no water being sucked from the bucket . One side of hose attached to washer the other dropped in bucket is...
THESE ARE RUBBISH, I SPENT SEVERAL HOURS TRYING TO GET MINE TO WORK AND ENDED UP SENDING IT BACK AS NOT BEING FIT FOR PURPOSE. THE HOSE BETWEEN THE WATER SUPPLY AND THE MAVHINE NEEDS TO BE FULL OF WATER BEFORE IT STANDS ANY CHANCE OF WORKING. I WENT FOR THE FILTER THAT SCREWS ONTO THE MACHINE WHICH YOU CONECT TO A NORMAL HOSE CONECTOR WHICH I THEN CONNECT TO THE TAP OF MY WATER BAREL. HOPE THIS HELPS
Sep 08, 2010 | Karcher 26408500 Pressure Washer 25Foot...
My karcher washer has lost most of its pressure it doesn't clean the bricks like it used to
The lance hose that attaches to the pressure washer keeps coming off when the power to the machine is turned on, i've only used this product four times since new in January this year.
Sep 06, 2010 | Karcher K2.26 Electric Power Washer
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher high pressure hose pops off high pressure outlet. I think it is stripped.
Try one of the products from your local DIY store, i,m talking about the two part putty that you mold with your fingers, can be drilled tapped and can do amazing bodges, plumbers are never without it! Good Luck - the Yeti
May 17, 2009 | Karcher PSI Electric Pressure Washer
Garden Logo
230 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
