Question about Video Game Consoles & Games
How do you plag a dvd on a xbox?
Can't play DVD
If its the the reggular xbox u cant play dvds without buying the xbox dvd remote that comes with a sensor that plugs into one of the controller ports
Posted on Mar 25, 2014
When we put in a game for our 360 system it says it's playing a dvd we can't get the game to work. how do i fix it so it says play game amd not play dvd? (it only does this with 1 game. the rest work fine
Ok if your for certain thats the original dvd drive and the other games work then its too many scratches on the disc or your laser lens needs wiped off with qtip and rubbing alcohol.
If you get an xbox thats say play dvd all the time on every game and it says to play this disc stick in a xbox 360 console then its the wrong dvd drive for that motherboard and you wont get the key (on a chip in the motherboard on the cd drive) unless you have the original dvd drive taken out of your xbox. Then you can just switch that little motherboard on the bottom of the dvd drives and it will read games. This is for those who will look at this with a xbox off ebay that they cant figure out how to fix. Its just an expensive dvd player.
Dec 26, 2010 | Microsoft Xbox 360 Console
Way does my xbox 360 say play dvd when there is a game in it
my xbox 360 says play dvd when there really is a game in it
May 21, 2010 | Microsoft Xbox 360 Console
My xbox 360 saying play dvd then it says to play it in an 360
call microsoft and describe the problem to them, follow the steps they give you.
May 14, 2010 | Microsoft Xbox 360 Console
check the firmware if not compatible with you game
Mar 25, 2010 | Microsoft Xbox 360 Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
100% burns xbox360 game but says play dvd when i put in xbox
Chances are what you are copying is COPYRIGHTED and the electronic protection will prevent you making a USABLE copy that the Xbox will run.
Nov 05, 2009 | Sony Computers & Internet
Same problem
If you have a flashed Xbox 360 it could be that the new game has a protection called Wave3.
That protection makes the games to run as a DVD if the speed of the dvd is not 12X.
Because when you got a flashed DVD, your dvd doesn´t play games and dvds at 12X speed.
That makes that wave3 is feeling a higher or lower speed than it should be and blocking it and says Play DVD. Exactly the problem you got.
Jul 27, 2009 | Microsoft Xbox 360 Console
Played too many dvds on the xbox, now it says play dvd notplaygam
best thing to do is send it back in to microsoft, if you open the xbox 360 case you will void the warranty, and they wont bother helping you. If you have already voided the warranty, you can find xbox 360 dvd drives on ebay or craigslist for around 30$ USD. Only the drive alone, not a whole xbox
Jan 01, 2009 | Microsoft Xbox 360 Console
I get the same error
Are you trying to play HD-DVD with out the XBOX HD Player?
Aug 18, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
50 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
