Question about Yamaha POCKETRAK C24 POCKET RECORDER
Stop function Hello! After pressing the stop-button of my C24 it takes some seconds/minutes until the recorder finally stopps. Can you help me?
  • 2 more comments
  • Susi Safari
    Susi Safari Mar 25, 2014
    to concrete the question: after pressing stop button it takes minutes until I can start recording again, in the meantime it is on stop. Meanwhile there is another problem: the c24 shows that it is recording, but if I want to listen to the records there is nothing.
  • sjdemers Apr 08, 2014
    You need to go back to the menu to access the playback menu.
    Then try it. If still a problem try time search in the playback menu.
    As far as recording pause before starting, Check in your record menu if you have set the timer to start at 30sec. which seems like minutes when waiting. If all else fails, do a menu reset in common menu section. Remember that many of the menus can be scrolled down to access a second page. Good luck.
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
How to set time for aquastar N0 4095
When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
Nov 02, 2009 | Watches
Binatone e920 quad phone with answer phone - can't record ogm.
Have had the same issue with a single handset. Finally located our manual:
1. Press and hold MEMO (FAST FORWARD) button until you hear a beep.
2. Record your memo, speaking from approx 15cm away.
3. As soon as you have finished speaking, press ON-OFF/STOP button to stop recording.
Hope this helps :)
Aug 13, 2009 | Lands Phones
Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Aug 05, 2009 | Watches
How to get a message on a telstra m450 answering machine
To change the answer message, hold ans on/off then HOLD the skip back button, don't let go until you finish the message, to change the amount of calls untill it plays the answer machine hold skip forward button till it says how many the press the forward button till you are happy, to change date and time, hold stop, it will say the day to change press skip forward, then press stop again, it will say the hour, press skip forward, then stop the minute, then skip forward, then stop again to confirm, i belive it is in 24hour time as well, when changing the time, but not on playback.
Hope this helps
Feb 08, 2009 | Lands Phones
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Finalizing dvd
Unplug the device from the outlet and wait 15 seconds before plugging back in. This will reset the device and stop the process, but it will not complete the process so you will have another incomplete dvd. Once you plug the device back in, you should be able to open and remove the disc and all functions should be back to normal. Let me know if you need further assistance.
If you do not mind, please rate my help I would greatly appreciate it.Thanks
Aug 14, 2008 | Panasonic DMR-EZ17 DVD Recorder
Yamaha POCKETRAK C24 POCKET RECORDER Logo
83 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
