Question about Kenmore 63942 Dryer
Kenmore Elite Dryer button won't stay on - no heat
I have to push something heavy against the button to keep the dryer tumbling but after all that, it ran for awhile and when I checked the clothes there was no heat.
  • 999 Answers
There is a switch on the motor, (centrifugal) that bypasses the push to start once the motor is turning. It is in the heat circuit also. Look there first...Eric
Posted on Jun 15, 2009
Why won't my dryer heat up?
There are several reasons for no heating on a Tumble Dryer. The heating element could be faulty ( open circuit.) There are several thermal cut outs which can also go open circuit The only way to check is with a Multi Meter by a qualified service engineer.
May 26, 2012 | Kenmore Dryers
Kenmore Gas Dryer 11072212101 won't heat. we
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Kenmore 63942 Dryer Logo
455 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
