Question about Pioneer FH-P5000MP CD / Cassette Player
No sound but car audio system is working
I changed the battery
I recently changed a discharged battery of my Toyota Sequioa 2008 model, and now my entire JBL Navigation and Audio system is not working.
by changing the battery with out maintaining a voltage for the radio and any other electronic gear , you have lost codes and other operational information that you will have to reinstall to get it all to work again
Jul 07, 2016 | 2008 Toyota Sequoia Limited 5.7L V8
Kenwood car audio problems battery change
Check the owners manual for the car or stereo, it may have a theft proof setting.
Jan 08, 2014 | Kenwood Kdc-u453 Car Audio Radio Iphone...
I have an Eclipse AVN 5504dm. It does not not to play anything. Screen just show Eject CD, eject DVD and eject MD. All instructions are in Japanese. Help Please?
u need the disc t reboot system (shutting down the sound system was Eclipse answer to stopping theft) try ur local car dealers, they have discs for those sort of systems
Feb 04, 2013 | Car Audio & Video
Can one fix remote control for Cambridge sound model 88?
Take it to a Tv repair shop to see they can do something, solder connections become bad, and may need a touch up.
Mar 31, 2012 | Cambridge Soundworks Soundworks 88 CD...
No sound
For no sound, if you have the cd driver of your motherboard then re-install it to update and fix the hardware error. If you do not have the cd driver, you have to read your motherboard brand and model then download the driver from their official with compatible audio driver to your operating system. If you installed it properly but still the same no sound, try to remove the battery on your motherboard for about 10 seconds then put it again the battery then turn on your computer then press F2 or DEL key to change the system date and time. Check for audio again and still no audio or no sound then format your computer but you must back up your data or files first because when formatting it will erase the entire data or files within that partition. Have a nice day.
Mar 11, 2011 | Computers & Internet
Radio won't work on my Dual XD1222
same problem, but if i disconnect unit or car battery systems (resets?) works again for a day or two then problem comes back
Feb 05, 2010 | Dual Car Audio & Video
How do i shut off the security system after replacing the battery
On EX, SE, and EX V-6 models
If you are talking about the overall security system in which the horn sounds and a combination of headlights, parking lights, side marker lights and taillights flash (and may also involve your radio), the alarm continues for two minutes, then the system resets. To reset an alarming
system before the two minutes have elapsed, unlock either front door
with the key or the remote transmitter. I believe this works when a battery has been changed.
If you are talking about the radio, Your car’s audio system will disable
itself if it is disconnected from electrical power for any reason. To
make it work again, the user must enter a specific five-digit code in the
Preset buttons. Because there are hundreds of number combinations
possible from five digits, making the system work without knowing the
exact code is nearly impossible.
You should have received a card that lists your audio system’s code
number and serial number. It is best to store this card in a safe place at
home. In addition, you should write the audio system’s serial number in
this Owner’s Manual. If you should happen to lose the card, you must
obtain the code number from your Honda dealer. To do this, you will
need the system’s serial number.
If your car’s battery is disconnected or goes dead, or the radio fuse is
removed, the audio system will disable itself. If this happens, you
will see ‘‘Code’’ in the frequency display the next time you turn on the
system. Use the Preset buttons to enter the five-digit code. If it is
entered correctly, the radio will start playing.
I hope this helps you.
Oct 23, 2009 | 2002 Honda Accord
Audio/Video System troubleshooting
there is a penny in your CD player slot. I had the same issues. Evertime I went over railroad tracks or severe pot holes my audio would go mute. The penny is moving around inside, on the CD player's electronic board and sorting out by letting multiple circuits make contact, so the penny was removed and everything is good. It killed my DVD System, I had to have it replaced on the dealership. I guess the previous owners kid put the penny in, mimmicking like a CD. I have had my Quest 3 weeks, probably one of the reasons they traded it in........
May 25, 2009 | 2004 Nissan Quest
MY 2006 INFINITI M45 AUDIO SYSTEM QUIT WORKING
I had the same thing happen. Any resolution?
Apr 05, 2009 | 2006 Infiniti M45
Changing battery on 2003 93 sedan, radio sound is bad
If you disconnected the battery incorrecdtly you may have blown some wireing that has then blown the speakers,if speakers are blown they sound really crackelly or dont work atall (disconnecting the battery would be taking the red wire (+) off first and incorrectly replacing the wires would be connecting the neggative first (-). its not herd off but it could be the problem??
Jan 07, 2009 | 2004 Saab 9-3
Pioneer FH-P5000MP CD / Cassette Player Logo
16 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
