Question about HP Jetdirect 175x Print Server
Reset jetdirect-150x reset jetdirect 150x
    Champion:
  • 411 Answers
Connect power then Push the little "reset button" on it.
Posted on Aug 05, 2014
Jetdirect ex default ip
Usually it it set to pick up IP from DHCP/BootP.
If someone had assigned a fixed IP and it is now unknown. It is better to reset the print server to factory default by pushing the little reset button,
Then check you DHCP server for the newly assigned IP address.
You will need a version of HP Jetadmin or HP webjetadmin to configure this print server
May 13, 2014 | HP JetDirect EX Plus Print Server
Hi, I need to reset my Printer using cold reset option. please help.
? Cold Reset
CAUTION All HP Jetdirect settings are also reset. Be sure to print a configuration page
before performing a cold reset. Make a note of the IP address that is listed on the Jetdirect
page. You must restore the IP address after performing a cold reset.
Use this item to unlock menus that have been previously locked and to set all control panel menu
items (including EIO settings) back to the factory defaults. However, using this item does not clear
the values in the SERVICE menu (such as the serial number and page counts).
NOTE Before performing a cold reset, print a menu map and a configuration page.
Use the information on the configuration page to reset any customer-set device configuration values that the cold reset procedure changes.
Apr 14, 2011 | HP LaserJet M5035 MFP Printer
Can anyone tell me what an error message 82.0180 means on an HP Laserjet 4100?
Error 82.0180 means that the JetDirect Firmware is corrupted. Refer to your manual how to cold reset the JD (JetDirect) card. JetDirect card enables network printing. If problem persist after cold reset, you may need to purchase a new JD card or bring your printer to HP service center for repair.
Aug 19, 2010 | HP Office Equipment & Supplies
I have an error code 58.04 on my hp color laser jet cp3525n can you help me out to reslove this error
8.4 suggests that engine power supply failure. The engine power supply mounts in the middle of the machine under where the toner cartridge resides. Lots of work to get to, I'm afraid. Need a service manual? Check out the link below. . .
http://www.image1products.com/techdocs/HP.htm
You could try cold reset:, if you can?
1. Turn printer off.
2. Hold the GO key
3. Turn printer on.
4. Continue to hold the GO key until the printer reads COLD RESET.
5. Release GO.
- INITIALIZING appears.
- Then, RESTORING FACTORY SETTING.
- Followed by OFFLINE.
6. Press the GO key to put back on line.
NOTE: A cold reset resets the HP Jetdirect card. Remove HP Jetdirect card before performing a cold reset
Apr 09, 2010 | Office Equipment & Supplies
ERROR SERVICE 49.FF95 IS COMMING
ust had one here do the same - it came in with a blown out fuser sleeve where the ends shredded as the heater strip's slick surface went dull (coating wore off on the ground end, caused to to stop while the rest of the sleeve turned and twisted the snot out of it) so I never ran it before I rebuilt the fuser and this is a rare one where the heater has to be replaced. Inserted the rebuilt fuser, got the 49.FF95 error - looked it up and most tended to refer to doing a cold reset or replacing the formatter if that didnt get it. Tried the cold reset, nada. Ran an engine test, ran ok but still the error. Reseated the memory dimm - nada. Swapped position of the boot select jumper on the formatter - nada and swapped back with no change. Hmmm this is BS! Started wondering if my rebuild had something to do with it so I installed a temp RM1-1082 fuser and had the error also so time to focus on formatter (with the embedded POS Jetdirect). Read the above comments referring to the Jetdirect possibly being a cause but it's not connected, it's stand alone. Ok next comment says turn off the internal LAN - BINGO! Error gone. It's the embedded crappy Jetdirect. So I ran some prints, all fine. Re-enabled the internal LAN - error is back. Verified Jetdirect failure. Ok so I go bac to diabled, download the 08.015.0A firmware and send it via copy/b on a parallel. Firmware went through properly and took. Re-enabled internal LAN - still get the 49 error. Must be that the internal LAN is AFU. Turned it back off and inserted an EIO Jetdirect and all is well.
Mar 30, 2010 | HP LaserJet 2420dn Printer
NETWORK PRINTER WON'T PRINT SINCE WE HAD A POWER FAILURE TWO DAYS AGO.
Check the jetdirect for a green connectivity light. If it's there, carry out a cold reset on the printer. Power it off and hold down the green button, power it on,keep holding down the green button until all three lights come on then release the button. it should read Cold Reset on the front panel. Once it goes ready, you will need to go back in to the menu system and setup the Jetdirect card again with it's IP address etc.
Oct 07, 2009 | HP LaserJet 4050 Printer
HPLJ P3005x Error
8X.YYYY EMBEDDED JETDIRECT
ERROR
The HP Jetdirect embedded print server has
encountered a critical error.
● Turn the device off and then on.
● If the problem persists, contact
HP Support.
Sounds like it's more than memory failure.
Sep 17, 2009 | Office Equipment & Supplies
How do i reset my hp jetdirect 170x
Unplug the power to the HP Jetdirect 170x, press and hold the test button. while pressing the test button, plug the power cord back into the device and continue holding the test button for another 5 seconds.
This will reset the device.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf
page 5-64
Aug 11, 2009 | HP Jetdirect 170x Print Server
Honda CRF 150X tappet settings
.003 for the intake and .005 for the exhaust should do nicely.
May 07, 2009 | Honda CRF 150 F Motorcycles
610N dissapeared no lights, empty EIO, reset no help
If you're seeing it intermittently, try the following:
-remove it completely
-power cycle the printer with it out
-check your contacts (be sure no bent pins, etc)
-Try it in a different slot if you have one (most HP's with an internal jetdirect have 2-3 EIO slots, but since you don't mention what model printer you have I don't know for sure).
If it's not talking after all that, likely the jetdirect is actually dead. It's been known to happen. I wouldn't waste the money on a replacement, you'll have better luck getting an external card and it'll be cheaper, too.
HP sells both the JetDirect 170X and 175X externals; there's also the Linksys PSUS4, D-Link DP-300U, TrendNet TE100-P1P, or Netgear PS101NA. Price will vary between $45-80.
Mar 27, 2007 | HP JetDirect 610N Print Server
HP Jetdirect 175x Print Server Logo
170 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
