Question about Metra 99-9309 1 Or 2 Din Radio Kit 2007-10 Mini Cooper
Surging while driving - Metra 99-9309 1 Or 2 Din Radio Kit 2007-10 Mini Cooper
    Sergeant:
  • 182 Answers
Vacuum line
Posted on Nov 16, 2014
This engine has a surge; AT 35-45mph,it's a bit more prounounced, not as bad, but still there at 60mph. As the tach goes up some, then down, so does the motor, up then back down, etc.Any ideas?
About 73,200 results (0.82 seconds) Search Results
    Surging While Driving Between 40 and 50 MPH : Chrysler ...
    repairpal.com > Problems > Chrysler > Town & Country
    Around 35 mph (common street speeds) the engine will sometimes surge with noticeable tach fluctuations. ... I have a surge when coasting around 40-45 mph.
    Enginge surges RPMS drop while driving [Archive] - Chevy ...
    forums.trailvoy.com > ... > OEM Issues
    Mar 17, 2012 - 19 posts - ‎7 authors
    [Archive] Enginge surges RPMS drop while driving OEM Issues. ... I so hope somebody has a clue as to what is causing my '02 Envoy's (182k) engine to ... I'll be driving and when I get up to around 35 - 45 MPH sometimes my ...
    Hesitation and bucking on acceleration - F150online Forums
    www.f150online.com/...engines/476391-hesitation-bucking-acceleration....
Feb 09, 2016 | Cars & Trucks
I have a 2006 Impala the engine is surging at idle and when I driving
Check the vacuum hoses for a leak.
2006 Chevy Impala LS 3.5L Surge Under Load - YouTube
? 3:09
www.youtube.com/watch?v=sD-swFhMORM
Jan 22, 2013 - Uploaded by Gary Castle, Jr
Surge while driving. ... 2006 Chevy Impala LS 3.5L Surge Under Load ... How To Fix Or Prevent Stalling, Surging Or Rough Idle, Cleaning ...
Oct 02, 2015 | Cars & Trucks
2004 chevy malibu classic idle surges at park and get worse at drive
usually cleaning the idle speed contrlol valve from carbon buildup, fixes idle surge and stalling. try soaking vave in throttle body cleaner or inyector cleaner.
Apr 03, 2014 | 2004 Chevrolet Malibu
Surging idle
Bad throttle position sensor.
Nov 24, 2013 | GMC Yukon Cars & Trucks
Any check engine lights codes. I would check vacuum lines, intake gasket and plenum. Check your ignition coil. Throttle postion sensor maybe stuck. I would even clean the throttle body. May even be a speed sensor.
May 04, 2013 | 1993 Dodge Dakota
94 chevy astro rough idle and surge when driving
check throttle body and check for codes
Feb 06, 2013 | 1994 Chevrolet Astro
Engine surge and idle problem the car surges when driving and will not idle longer than a minute unless i step on gas pedal I have gave it a fresh tune up, oil change, changed fuel filters and checked the...
If your jeep has an EGR valve, try removing it and giving it a good clean with carb cleaner. A bad EGR valve will cause surging while driving.
hope this helps
Matt
Jun 15, 2011 | 1986 Jeep Cherokee
My car surges when i drive 50km/hr and stalls when i am in drive or park.
Sounds like a bad surge protector. They typically go bad as the car ages but can be repaired easily. Radio shack has surge protectors for about $10. Cut the plug end off the wire and splice 2 of the wires to the positive and negative post of the battery. The third wire around a screw on the body of the car. Start the car, the on-board will now nullify any surge and stall it has stored in memory. Go for a ride and enjoy.
Jul 02, 2010 | 1990 Buick Century
92 honda accord surges or idles high
Have you install a timing belt recently? If you get it off a tooth it will idle high and surge
Aug 21, 2009 | 1998 Honda Civic
Seagate Harddrive Stopped working
there was a surge of power threw your system you need by an industrial power surge protector for your system now for the harddrive ive found that if you turn over and mount on static bag with box your harddrive should run long enough for you too collect and move data too another drive but never place on metal surface
i had the same problem i had a surge blew my hard drive a friend suggested turn over and then do a dump to another drive
after that i went out and purchased an industrial surge protector cost a pretty penny but has saved my system many times its called a belkin industrial surge protector about 80 dollars cheapies dont close quick enough hope this helped
May 07, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Metra 99-9309 1 Or 2 Din Radio Kit 2007-10 Mini Cooper Logo
47 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
