Question about JVC RX-5020VBK Receiver
Fuse lamps what size fuse lamp do i need
Tail lights not working fuse is good bulbs are good. What do I need to check now. 2008 Pontiac G6
What fuse is good ? Did you check fuse in rear fuse box ? Also did you check park lamp relay .
Park, Tail and Marker Lamps
The park, tail, and marker lamps, including the license lamps, are turned ON when the headlamp switch is placed in the PARK or HEADLAMP position, or anytime the headlights are requested. The PARK LAMPS fuse in the rear fuse block supplies battery positive voltage to the PARK LAMP relay switch contacts. The PARK LAMPS fuse in the rear fuse block also supplies battery positive voltage to the PARK LAMP relay coil. When the park lamps are turned ON, the body control module (BCM) energizes the park lamp relay. Current flow is from the PARK LAMP relay to their respective park and marker lamps and to ground. Ground is provided at G101, G102, G401, and G403.
Fuse Block - Rear
Left side of the rear compartment, behind the left rear wheel well
Jan 08, 2017 | Pontiac Cars & Trucks
Which Fuse do I need for a Brake Lamp Relay?
Go to the GM owners site (click link below) and select your make and then download the owner's manual, all fuse information is in there.
https://my.cadillac.com/vehicle/2000/Escalade
Oct 07, 2016 | 2000 Cadillac Escalade
Need to know reading lamp bulb size
Marked on the lamp is the #
You can print an automotive lamp chart off the
internet also & match up the lamp size,socket base,
current & such
Mar 09, 2013 | 1997 Mitsubishi Eclipse
2001 F150 supercrew w/ factory towing - No tail lights on trailer
Not sure which fuse you checked.
The Engine Compartment Fuse Panel ( Battery Junction Box / BJB ) is where the fuse is for the trailer tow adapter parking lamps.
Fuse # 5 is the fuse for the parking lamps, and the reversing lamps.
Next is the trailer tow adapter park lamp relay. This is what BJB Fuse #5 feeds, and the coil is operated by the truck's parking lamps. This is also in the BJB, Relay 201, it is the 1/2 size relay.
Not sure what you took a resistance reading from on the trailer tow adapter.
If you want, you can pull the trailer tow park lamp relay, and jumper the normally open contacts, which should provide power at the trailer tow adapters, regardless of the truck's lights.
This is the wiring diagram for the trailer tow park lamps
Mar 09, 2010 | 2001 Ford F150 Styleside SuperCrew
It is flashing H 4 over and over
H4 flashing mean problem on FUSER section.
Problem on three things
1 Heater lamp burned out.
2 Fuse out of order
3. Thermostate damage.
Problem solve: Reset this code
Press C-Photo-C-photo press 14 press Start key
Note: Its only A4 and legel size copier.
Other thinks # interrupt C interrupt.press 14 press Start key.
Jan 25, 2010 | Office Equipment & Supplies
10 x 5 watt lamps and a 10 mtr run of cable what size cable do i need and what size fuse
10 x 5 watts = 50 watts, and 50 watts at 12 v = 4.17 Amps. You can use a 5A fuse if you want to cut it close, but some lamps have a momentary draw when they're powered up that exceeds their nominal (5W) rating, so I'd suggest a 10A fuse for it.
For cable size, you should be fine with 14GA wiring for a wattage in this range.
Jan 25, 2010 | Car Audio & Video
Fog lamps dont work i check fuses and relay the switch shows the fog lamps are on
If you have not replaced the headlamp with HID, the next thing, are the high beams on ?
If you turn the high beams on, the indicator lamp on the main headlamp switch should go out.
Next thing would be to check the fog lamp relay in the fuse panel ( passenger side kick panel by the fuel inertia switch ).
The fog lamp relay is a half size ISO relay, you should be able to swap with the trailer tow parking lamp relay ( R201 ), to test with.
The fuse you checked is the F17, the fog lamp fuse for Relay R202, correct ?
Nov 26, 2009 | 2006 Ford F-150
Epson 7550c projector - ELPLP07 lamp fuse.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 04, 2009 | Epson 5550c / 7550c Replacement Projector...
Magnavox model 50ML8105D/17 shuts down after only a few seconds and overheat and lamp failure lights come on , I`ve replaced the lamp , but the problem still occurs
We reduced the picture size to 4:3 and was able to get quite a bit more life out of the lamp, without it shutting down. It does take awhile to get use to. But is much better than a dust catcher
Jan 31, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
JVC RX-5020VBK Receiver Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
