Question about Pentax K100D Digital Camera
Shutter opening only half way getting stuck - Pentax K100D Digital Camera
How to fix a velux exterior shutter which is stuck half open, half shut
I am a Velux installer I am assuming you are discussing an exterior shade on the outside of the unit rite?
Mar 31, 2014 | Velux VSE-S01-2104-RM Copper Frame VSE...
Canon PowerShot S3 IS shutter problem. Shutter does not respond. Screen is black. No pictures are seen. It sounds like it it taking a picture, but doesn't. When looking into lens, it doesn't appear the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 20, 2010 | Canon PowerShot S3 IS Digital Camera
When I turn my camera on a get a black screen
Nov 07, 2010 | Canon PowerShot S3 IS Digital Camera
How much for fixing a Nikon D90's Shutter?
Hi philipteng,
I repairs cameras, flashes, lens and studio lighting.
I am in Virginia.
atdlee@netzero.com
Jan 14, 2010 | Nikon D90 Digital Camera with 18-105mm...
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Shutter is stuck on open position
shutter is stuck half way open and when the camera is turned on it says lens error 0x001110000 and then it shuts off
Apr 30, 2009 | Cameras
Shutter stuck half open
This sounds like the mechanism has worn. It is a straight forward service centre procedure, I wouldn't recommend trying to do anything that will make it worse. Leave it to Nikons engineers.
Mar 11, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Try to dismantle it and fix the shutter yourself before paying for repair.
Nov 06, 2008 | Olympus Mju 725 SW Digital Camera
Canon EOS Rebel G - The picture is cut in half
I'm afraid this is almost certainly a shutter fault - the second curtain of the focal-plane shutter is getting stuck half-way across the film and therefore not shutting properly. The fact that the other half of each frame is OK makes me think that the second curtain is not sticking totally but just moving very slowly for half of its run, thus seriously overexposing that half of the film. This is a repair shop job - unless you want to try it yourself: it may be just some dirt stuck in the track the shutter curtain runs in, but a fair bit of skill is needed to get to it & clean it without damaging anything!
Sep 29, 2007 | Canon EOS Rebel G 35mm SLR Camera
Pentax K100D Digital Camera Logo
16 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
