Question about LG 30FS1D TV
Automatically switch off
Where is the problem that i conclude
    Top Expert:
  • LG Master
  • 74,383 Answers
If the set switch off automatically, soon after switch on, it indicates a fault with its main board. If it switches off after some time of working, indicates, a loose or any solder defects with its main board or power supply regulator section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Pull up older posts there.
Posted on Mar 24, 2014
Ford escape troubleshooting
I believe the fluid/brake light is only intended to indicate the parking brake is on or the master cylinder reservoir is low . ?????
Wrong !!!!!! problem's with ABS can also turn on that light as well ! Take it a have codes checked .
Mar 11, 2017 | Cars & Trucks
My drl switch is bad iv'e concluded... but now i have no headlights high or low. is this a blown fuse from lack of drl switch replacement or what. i still have my parking lights but no headlights
Likely the Headlights work through the DRL switch, too. Replace the switch (get a used one from a used parts/salvage/wrecking yard) or from a dealer...might call an auto parts store, too.
GL,
Td
Oct 18, 2012 | 2001 Chevrolet Prizm
My samsung automatic washing machine wa7584c1 is giving me a 1E error why ?
Hello, the error code is due to a water pressure switch error the service manual says
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s also before replaceing the pressure switch assure that the tube that comes off the switch that connects to the tub on the tub end has no debris or soap build up inside the hose this could also make the switch show as an error if the hose had something in the end of it. Thanks again
Aug 23, 2011 | Washing Machines
Power to switch and turned on but no response from unit e.g. no fan or pump engaged. SMALLAIRE conditioner.
Check power in PCB. If yes, PCB is faulty. If you operate with remote and no response, try with another remote and conclude.
Jan 16, 2011 | Heating & Cooling
I have a dishwasher that is model # DB1100XTPQA and for some reason there seems to be no electric current to it now. After concluding there is power to the unit what else could be the problem.
If the power connection is good and tight at the wiring terminal box underneath the dishwasher the problem is the door switch.
The incoming power goes to the door switch first.
With the door latched and the switch working correctly,the power then travels to the timer.
Check the door switch.
Jun 25, 2010 | Dishwashers
I am looking for a contol board for a miele s143 stick vacuum. The vacuum wont start but when I supply power directly to the motor it spins. I think the switches are OK so I have concluded it is the...
you should check the cord and switch's for continuity, the boards are usually pretty reliable, you could check the board for any bad solder joints, at least that would be obvious.
Sep 14, 2009 | Vacuums
Reset pswd
You can reset the unit to factory default... this will set the password to factory settings.. then you can create new password
Jun 16, 2009 | IBM Nways 8275 Model 217 Networking Switch
Bought it 2nd hand
After conducting extensive research, I have concluded that there is no ID and/or password to reset. According to my research, this is an "unmanaged" switch. It's plug-and-play all the way.
http://www.dlink.com.ph/products/dlhome.asp?sec=&pid=71
Jun 11, 2009 | D-Link DES 1016 16-Port Ethernet Switch
My maglite 3 d-cell has stopped switching on, therefore I conclude that it's the switch which has broken. How can I get it repaired please? My maglite flickers on and off when I turn the end cap and...
the switch in the mag light is water proof. therefore you can open it to fix it.
the light is cheap enough these days. I suggest just go buy another one.
Dec 29, 2008 | MagLite Mag-Lite& Flashlight
Repair manual
Problem solved! The main power thingy (the thing with the big red wire coming out of it) was all black and dusty. There was 'soot' all over the whole insides of the monitor. I concluded that this monitor should be laid to rest, and a new flat-screen monitor erected in its place.
Nov 18, 2007 | ViewSonic G220f (Beige) 21" CRT Monitor
LG 30FS1D TV Logo
19 people viewed this question
Computer Repairing
Computer Repairing
