Question about Frontgate Vornado Tower Circulator Fan - Frontgate
How do I Open the Vorando Tower Fan to clean
I can not open the Vorando Tower Fan
  • Frontgate Master
  • 16,828 Answers
Use a flashlight to look through the vents on the front. You should see screws.
Posted on Sep 25, 2016
I have a tower fan 42" that produces no air. I have checked the fuse (ok), I have connected to black wires that were way from their harness....still no air
apparently nobody gives a hoot will throw the piece of **** in garbage and never buy a product from this company ever again.
its not a profanity it is a bodily function
Nov 01, 2014 | Bionaire BT440RCU Remote Control Tower...
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
How do i change battery on vornado remote
it may be held on with a tiny screw.. it needs removed before you can open it up
Aug 01, 2014 | Frontgate Vornado Tower Circulator Fan -...
Should I run unit with windows open and atic fan on????
It seems that you would be changing lots of air volume with windows open and the attic fan on. I suggest turning off the unit unless the room is closed, so it can recirculate and clean THAT air.
May 25, 2011 | Oreck Walnut Air Purifier Air8Wa Air...
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
Fan is working but is not cleaning air.
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Breeze AT Living Air Purifier
How do i clean a lasko tower fan model 2551 as it is dusty inside
best is if you have an air compressor and blow it out, if not, a paintbrush and vacuum will do. remove grill/cover if you have to. make sure unit is un plugged.
Sep 06, 2009 | Air Purifiers
How do you clean the squirrel cage
i use a water hose or a stiff brush like a wisk broom
Aug 14, 2009 | Enviracaire Tower Fan with Air-Freshening...
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
I used a can of compressed air to clean my fan blades and this did the job. I bought a 6-pack of 3M Dust Remover at Sams Club to save money. Hope this helps.
Dec 18, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Frontgate Vornado Tower Circulator Fan - Frontgate Logo
154 people viewed this question
Top Frontgate Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Frontgate Air Purifier Expert? Answer questions, earn points and help others
