Question about As Seen On TV H2O Mop Ultra
Pump stopped pumping
Pump just stopped pumping. It was full and was working fine
Fuel pump?
replace the in tank fuel pump--its eventually going to stop all together, usually when the tank is full.
Mar 24, 2014 | 2002 Chevrolet Malibu
Heater gets cold when i stop accelerating
The coolant is probably low. Check that first, if it is full then the water pump is probably worn and not pumping effectively any more.
If you need further help, reach me via phone at https://www.6ya.com/expert/forrest_f5a3e9d21691ce99
Dec 26, 2013 | 2001 Saturn SL
Bobcat 533 tilt and lift not working
The hydroloic pump that operates the lift is failing. The drive operates on a separate pump so that pump is good. Find the pump that the lift rams hoses go to. That's the one you need to examine. Check all connections. Electrical, hydrolic lines, vacume hoses... everything. If all that checks out, then you need to have the pump rebuilt or replaced
Nov 10, 2017 | Cars & Trucks
My whirlpool ultimate II washer was working fine and just stopped. I could smell something like wiring getting hot and now it won't do anything. The basket is still full of clothes and water.
remove the frame,pop off the two clips that hold the pump on and pull the pump off of the motor shaft,start the machine,if it runs you have something stuck in the pump.if it does run get a shop vac and remove the water from the tub,then remove the clamps on the hoses just push them down the hose with a pair of plyers then loosen one hose at a time so you can vac out the water,once you have all the water out you can remove the pump and see what's stuck in it,usually,a sock,womens underwear or a metal from a bra.if it's not the pump move the shaft on the motor with the plyers were the pump slides onto,you could have a flat spot on the motor and by moving the motor at the shaft might free it up,i've done this,some motors will run all the time after this or it could stop again on the next load,watch it and see what happens.http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw&feature=pyv&ad=5457341861&kw=washer%20pump
watch video and it will show you how to get at the pump and motor.good luck with your washer
Jan 23, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Power steering pump replaced, start to work ok, after 10 milles driving, steering wheel is hard, like pump is not working, under hood everything look ok.
YOU HAVE AIR IN THE POWER STEERING SYSTEM.YOU NEED TO BLEED POWER STEERING PUMP FIRST BEFORE DRIVING VECHICLE.CHECK POWER STEERING FLUID LEVEL ADD MORE POWER STEERING UNTIL REACH FULL COLD MARK..RAISE VECHICLE FRONT WHEELS OFF THE GROUND.START ENGINE LET IT IDLE WHILE TURNING STEERING WHEEL LEFT TO RIGHT NON STOP DONT LOCK OR STOP STEERING WHEEL KEEP TURNING IT SEVERAL TIMES CHECK POWER STEERING FLUID IF LOW ADD UNTIL YOU GET COLD MARK ON DIP STICK DONT OVER FILL POWER STEERING PUMP BLOW A SEAL.IF POWER STEERING FLUID LOOK TAN COLOR SYSTEM FULL OF AIR.TURN OFF IGNITION LET CAR SET FOR A WHILE CHECK FLUID LEVEL.IF STEERING WHEEL FEEL STIFF HARD TURNING DONT DRIVE CAR UNTIL YOU HAVE NORMAL STEERING.IF STILL HAVE AIR IN SYSTEM BLEED SYSTEM UNTIL AIR IS OUT.
Feb 25, 2011 | 2002 Chevrolet Avalanche
Everything works fine but it will not spin
Hi, you got water pump problem, some pump have a filter you can remove and clean, or some some small clothing could get into it. or you can open water pump and manually check for foreign object. you can empty machine, by lowering drain hose to floor level, you will need somthing to collect water, then check pump.
Aug 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Wind shield washer fluid stopped working 2005 excursion
Pull resivior and see if it gelled up around screen for pump motor.Cheaper washer solvents tend to do this,If so you can clean screen and it should be ok.Note sometimes you can look down in liquid with flashlight and see gell in resivior.
Jun 19, 2009 | 2005 Ford Excursion
Fisher & Paykel GW712 error code 37
Ultimatly replaced the new pump with a "genuine" pump from F&P which fixed the problem permenantly. Interesting is that all the id tag details of the pump manufacturer were exactly the same on both "new" pumps. The only noticable difference was the impleller design which could have possibly been overloading the "generic" pump, causing it to cut out. One final note; it takes eight complete load cycles to be completed after a fault code has been repaired before the code resets.
Jul 21, 2008 | Washing Machines
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
As Seen On TV H2O Mop Ultra Logo
Top As Seen On TV Televison & Video Experts
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Televison and Video Expert? Answer questions, earn points and help others
