Question about Axcent Of Scandinavia Watches
Need manual for Axcent Zero Design watch (don't know how it set it up)
I have bought a watch recently on second hand (thought watches can't be hard to set up... right?). And now for couple of days I am struggling to set it up and can't do anything :/ Anyone has a manual and could send it as a pdf? I tried to look for it online but nothing there!
SOURCE: How to set time on Diesel DZ 7071 Watch
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
Posted on Dec 25, 2007
SOURCE: setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Posted on Mar 09, 2008
  • 4 Answers
SOURCE: Setting Date. Seiko SGF204 (w/ 7N43 Band) French & English Days.
If you pull out the stem 1/2 way, you set the date one direction, and the day the other. If you pull it out all the way, it moves the hands and sets the time.
Posted on Feb 03, 2009
escapement
  • 2334 Answers
SOURCE: Techno Marine MO4 Watch, Seconds hand doesn't reset to top cente
You do not need to return the watch. It has self adjusting features (operated by the owner). Pull out crown to the first click, then push and hold the pushbutton at 2 o'clock to adjust the hand. When done - push crown back in.
If it doesn't work, pull out crown to the second click and do as described above.
Rate me, please.
Posted on Mar 22, 2009
escapement
  • 2334 Answers
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Posted on Apr 03, 2009
How to set time on a Lorus watch Z001 X001
Digital
Press the button on the bottom left-hand side of the watch to change between the modes on the watch.
Press and hold the button on the bottom left-hand side of the watch for two seconds until the seconds begin to flash.
Press the button on the top right-hand side of the watch to set the seconds to "00" and press again to set.
Press the button on the top right-hand side of the watch again until the hours flash. Press the button on the bottom right-hand side of the watch to change the hour display. Press the button on the top right-hand side of the watch to set.
Repeat step 4 to set the year, month and day on the watch.
Analog
Pull the small knob on the right-hand side of the watch, also known as the crown, out one click.
Turn the crown until the previous day's date is displayed.
Pull the crown out one more click. Turn until five minutes ahead of the correct time and then turn back to the correct time.
Push the crown back to the side of the watch. The watch is now set.
Mar 31, 2018 | Lorus Watches
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
I recently bought a Kenneth Cole KC 3790 as a gift and I am tying to set the date...the date is presently Saturday 27th February and I am having difficulty getting to the 27th day of February on the...
Pull out crown to the time setting position (second click) and set time to 5.30 pm or am. Push crown back completely. Pull out crown to the date setting position (first click) and set it to 26th, then pull out crown further out to the time setting position (second click) and adjust watch hands forwards until the date changes to 27th. Date is changing at midnight, so, continue to adjust hands forward to the right time. Rate me, plz.
Feb 27, 2010 | Watches
Seconds ticker jumps,stops,jumps
It means that the reserve power is getting low and the energy cell needs to be fully recharged by exposing it to light for a period of time outlined in your owner's manual. This may also occur after fully recharging your watch after a complete discharge of the energy cell. If you have fully charged your watch and the second hand continues to move in two second intervals, you need to do an all reset of the watch. For simple analog models, pull the crown out to the time setting position for 30 seconds, then return the crown to the closed position next to the case, then set the time. For multi-function models, please refer to your owners manual.
Jun 15, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Automatic watch seconds hand stops at 8
The 'dit' at the 8 is higher than it should be. Slightly lifting or unbending the tip of the second hand will correct the problem.
Feb 20, 2009 | Watches
Timesetting on Athletic Works wristwatch
I have a AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
Feb 17, 2009 | Oakley GMT OAK0531 Wrist Watch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Seiko SNA413P1 second hand not on 0 exactly
It is probably the way the second hand was placed onto the watch when the watch was put together. The hand will only move in a set interval so if it's "off" you cannot fix it unless you have someone take the watch apart. I would not worry about it being a fake because honestly Sekio watches are not expensive enough to fake. Here's a good rule of thumb, if the watch cost under $1000 then it is probably not going to be something that people will make a counterfeit model of. Finding a "fake" Seiko, Citize, Bulova, or any mid-level watch is not likely.
Jan 02, 2009 | Seiko SNA413 Wrist Watch
Watches Logo
512 people viewed this question
Top Axcent Of Scandinavia Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Axcent Of Scandinavia Watch Expert? Answer questions, earn points and help others
